I600 hydraulic oil capacity |
| Author | ||
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9693 |
Topic: I600 hydraulic oil capacityPosted: 16 Mar 2022 at 6:01am |
I need to change the hydraulic oil on my new to me I600 backhoe.
I need to know how much oil to buy? I plan to drain the loader frame reservoir and the transmission reservoir. Are they separate of each other? Can they use the same type of hydraulic oul? Thank you in advance. |
| Sponsored Links | ||
Joined: 11 Sep 2009 Location: illinois Points: 89291 |
Posted: 16 Mar 2022 at 8:48am |
Thad, im not much help, but our CASE 530 hoe/ loader has the frame full of oil. It takes about 10 gallons of universal tractor fluid....... The transmission is just like a farm tractor. Not part of the hydraulic system. I dont remember, but probably around 4 gallons, and it is the same universal fluid.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54730 |
Posted: 16 Mar 2022 at 6:32pm |
That, book says 5W20 ND for PS system. Can't say how much, but a gallon or so would be my guess... As for the hyd, any good universal hytran should do the trick!
Thad in AR.
Posted: 16 Mar 2022 at 7:14pm |
Dave on this one the hydraulic reservoir from the loader is plumbed in to the power steering fill on the front end |
