I give up
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Topic: I give up
    Posted: 06 Jun 2018 at 10:51pm
I have searched high and low, even found an original owners manual. I can't find the lift capacity of a 5020 3pt hitch anywhere. Do the experts know? It's a fwa if that matters.
Thanks
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 2:21am
I have a MF 220 which is about the same tractor as the AC 5030 and the 3pt will lift
way more than the front end can hold down even with a couple front weights on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 5:51am
I looked up on tractordata, but no number however it's kinda like my Kubota BX23s in size,hp, features, so I'd guess 1,000 #. Tires should be stamped what they will support..while NOT 'lift' amount, a good indicator. Lifting is one thing but unless you weigh down the front..well it could be 'interesting' !
Jay
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 7:19am
For what it is worth , relief setting is 1700 PSI @ 1285 RPM
  In the Attachment Lit. for 5020 it shows a Rotary tiller ,weight 585.
Edited by Fred in Pa - 07 Jun 2018 at 8:10am
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 7:26am
While the pressure is a start, there's a lot of math involved to compute what it will lift. 'silly' little details like cylinder size, pivot points, hyd eff( 90% +- ?),strength of lift arms, how close the load is to tractor, etc.
Perhaps an easier route is to see what implements can be used with it. The MFR/seller should post the weight(say of a plow), if only for 'shipping purposes'.
just an idea.
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 6:38pm
How wide was the allis tiller that weighs 585#? I find it was a model 66...is that the working width?
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 7:29am
This weblink doesn't answer your 3pt capacity question, but I thought It was an interesting read.
http://gardentractortalk.com/forums/topic/37081-a-little-on-the-hinomoto/
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2018 at 5:09am
I dug out my two original (1979 & 1982) sales literature that shows specs for AC 5020 4wd. In both, it only list 3pt as category I, with no lift capacity numbers.
In the 1979 lit, it has only one 50" wide rotory tiller( no model info about it.)
In the 1982 lit, it shows two rotory tillers - a 48" & 54". Other than stating these attachments were AC branded or Companion Branded, they don't list any further specs about them. Some other 3 pt attachments for it include;
72" Rear Scraper Blade,
72" Rear Grader Blade,
14" one bottom plow,
60" Rear mounted rotory mower,
Post hole digger-4' augers 6", 9", or 12" diameters,
66" Box Scraper,
1row 52" cultivator,
5.5' (16"blades or 6.5' (20" blades) Disk harrows,
48" Front loader,
60" snow thrower.
On another previously replied note about it's tire load ratings. All tires, standard & optional, have a 4 ply load rating. In 1979, standard rear tires 11.2-24 or 12.4-24 4ply R1. In 1979-82, a 13.6-16 R3 4ply was available on 5020 2wd only.
75lb front end & 125lb rear wheel weights were also offered. The 75 lb front end weights somewhat resemble older 100 series slab style, except I'd say they're in more of a bar shape(long narrow shoe box size bar - maybe 4"x4"x14"?). A few pictures display a 5030 2wd with 3 75lb front end weights is pulling a 6.5'? 3pt disk in a field. A 5020 2wd has an AC 430 loader on it & states that loader at fully lifted has a capacity of 720lbs.
Edited by AC7060IL - 10 Jun 2018 at 7:57am
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2018 at 6:40am
Wow! Thanks for all the great info. It appears that they never published the number I'm looking for but the replies given on this thread have given me enough info to make an educated guess!
Thanks for all the help.
