Hydraulic outlet |
bobkyllo
Joined: 14 Sep 2009 Location: minnesota Points: 1569 |
Topic: Hydraulic outletPosted: 07 Mar 2019 at 7:47am |
This winter is dragging on and I've finished just about all my jobs for the winter. Now I'm scratching for things to do. One thing is on my white tractors the hydraulic outlets really suck to get hooked up to. You have to pull the hose twords you then at the same time push your implement into the hose and then release everything.
Have you guys ever converted your tractors to something better? I was thinking something like John Deere has where you just push the hose in and you're done. I looked at the valves all states offered with the handles on the valves to help in hooking up hoses with pressure on them but they want a pretty penny for them |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12421 |
Posted: 07 Mar 2019 at 8:07am |
So why not plumb in the John Deere style that you like?
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 07 Mar 2019 at 9:36am |
Bob if you come over I've got a million and one things you could do.
It's never ending with things for me to do.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4279 |
Posted: 07 Mar 2019 at 9:48am |
I'm not impressed with the couplers on Dad's 4230! Like Pioneers a lot better.
Tbone95
Posted: 07 Mar 2019 at 9:55am |
Really? The JD conical style, with the lever under the coupling to turn flow on? Huh....I LOVE those compared to pioneer, and wish Deere had never switched. Yeah, they wear out over time and need parts, but when in good condition I really like them.
bradley6874
Joined: 05 Sep 2010 Location: salisbury md Points: 1349 |
Posted: 07 Mar 2019 at 11:07am |
The reason for the pull out to hook up allows the hose to unhook if caught and pulled or if you forget to unhook one of them btdtq
IBWD MIke
Posted: 07 Mar 2019 at 11:25am |
They may be worn out, I don't know. They have come uncoupled several times on me. Not crazy about hooking them up either. Probably doesn't help that I just don't like John Deere stuff.
Tbone95
Posted: 07 Mar 2019 at 12:50pm |
True, but the newer ones you can push or pull to release the balls, and will release for accidental causes like you just mentioned. It's nice because you don't have to fight against yourself to pull out the coupler while pushing in the hose. Push in to connect, pull out to disconnect, free to disconnect on emergency.
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 07 Mar 2019 at 8:06pm |
I put couplers like Tbone95 described on my 200. Same as the ones on a Kubota 9540 and others. They work on the ridged outlet with an npt to o ring adapter.
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 08 Mar 2019 at 7:06am |
The 7000 series couplers aren't too bad. The 7030 and 7050 weren't the greatest but many were updated to the later 7000 series. I have found that on some 7000 series the little lever or plate that you pull gets bent or doesn't have enough of a hump where the plate pushes the coupler. Easy to remedy IMO. I updated my brother's 190 from the type you mention to the 7000 series and will do my 200 this weekend.
Wink I am a Russian Bot |
bobkyllo
Posted: 10 Mar 2019 at 2:35pm |
Thank you for all the help. I'm going to try and clean my couplers and try and mount them a bit better. We will see how this works this spring. I may be revisiting this subject this summer.
fourthgeneration
Posted: 10 Mar 2019 at 8:13pm |
I put Safeway push/pulls on the 6080. I had to mill a new plate out as they are a bit smaller diameter. I’m going to do the same on the 7020 and 8070. There is a fixed body that may be an 8450 that I may put on our 185.
wekracer
Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1595 |
Posted: 11 Mar 2019 at 9:49am |
Does anyone make something like the later 7000 couplers. We bought a Steiger and it has all older Deere couplers and need changed out. I hate to spend what it costs for the pioneer lever couplers.
