Hydraulic Cylinder for WD45 and wheel disk
woodman Steve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodman Steve Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic Cylinder for WD45 and wheel disk
    Posted: 12 Dec 2018 at 10:11am
Where can one find a one way cylinder that will work with my WD45 system for my wheel disk?
Steve
Two WD45's
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2018 at 1:49pm
Any cyl with adequate length and the correct ends will work.  You would just put a vent cap on the unused end of the cyl. if it's a two way cyl.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2018 at 9:46pm
Needs to be a hi pressure cylinder and hose.
I have one that I don't use any more that I would sell.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2018 at 9:59pm
The original AC cylinders work best.They are still out there. High pressure,low volume.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2018 at 11:23pm
have one i may sell also;
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2018 at 3:00am
I have a few of them available. Some are NOS.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2018 at 6:28am
I have heard that for years but never have had a problem using regular cylinders on AC
tractors.Have you ever actually had a problem?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2018 at 7:39am
They will stretch the bolts on a low pressure cylinder then blow orings + will lift slow.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2018 at 8:33am
Guess I've been lucky never had a problem, have a regular cylinder on a NH mower now I've used quite a bit hooked to a D15 and a WD.What brand cylinder were you using when it happened?
alchpuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alchpuller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2018 at 10:40am
I have some aircraft MLG cylinders, 3000 psi system mineral oil fluid , 303 fluid works good
18 in travel extend only, you pay shipping and 10$ a piece, I use them on a bale mover and they work good with my WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2018 at 4:56pm
I have a 2 way Oliver cylinder I used on the 45 for several years, to lift the corn planter. Never had a problem, but I never let it hammer after it was extended all the way. If you raise it up out of the ground and move the lever to the hold position, you'll never have a problem with any 2 way remote cylinder. It will be slower than a regular Allis cylinder.
 I eventually found a cheap Allis cylinder at an auction. Gave $8 for it and then spent about $30 and 3 hours of my time to make a new rod and put new packing in it.
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2018 at 11:09pm
Most modern cylinders are made to handle at least 3000psi. Unless you have rebuilt the pump, it's probably not getting that high of pressure anymore.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2018 at 6:48am
Dad's WD pushed a wagon hoist cylinder apart once. After that Dad gave strict orders to not let the wagons go but so high.
Wink
I am a Russian Bot
