How do you move a hole ? |
Larry Miller ![]() Orange Level ![]() ![]() Joined: 21 Nov 2009 Location: NWIL Points: 907 |
![]() ![]() ![]() ![]() ![]() Posted: 13 Jun 2011 at 7:17pm |
I have had several situations where two bolt holes don't quite line up and one or both need to move less than half the hole size. Tried several things - all frustrating. How do you deal with that ?? Thanks, Larry Miller
I used to be young and stupid, now I am not young anymore.
E7018 ![]() Bronze Level ![]() Joined: 07 Dec 2009 Points: 167 |
A tapered reamer fits some situations. Truck frames is one spot that I like one.
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Round file. Milling machine and an endmill or slot cutter. Ordinary drill bit cocked in the hole back and forth to make the hole oblong. It widens both sides though. Or just a bigger drilled hole. Electronic industry used to plan for 1/32" oversize just to account for alignment.
Gerald J. |
TedBuiskerN.IL. ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
Tap the hole to the nearest size, and locktite a bolt in the hole. cut the bolt off, grind it smooth, and relocate your hole.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22823 |
Bridgeport mill, Larry. You have room to expand your workshop and I'll come over and show you some things you can do with it.
I envy you guys with mills and skill to use them. When I get to live my life over - that is a skill I will put on the redo list.
Ted - that is one I have not tried. I will put it on the should do list. Charlie - if you bring one over - I will make the room. Or, I can bring you a bag of holes and you can help me put them where they are supposed to be.
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5998 |
If it's mild steel, I weld the hole shut, grind smooth, then locate, punch, and drill new hole.
Jeff Z. NY ![]() Orange Level ![]() Joined: 11 Sep 2009 Points: 7326 |
Johnny Cash had the problem once.
He went to put in the bolts and all the holes were gone. I hate it when that happens. |
Larry, Have you got a die grinder? Harbor Freight and the big box stores have some cheap ones that work OK but use more air than a good one. A carbide burr in a die grinder will fix you up in a very short time.
I wanna see the bag of holes Larry. I almost bid on a bunch of used post holes at an auction cause nobody else would give a dollar for em. Then I got to thinking if they were used post holes, they would be filled up with old wood and some dirt around the outside so I didn't bid. I guess the farmer kept em.
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
I would suggest a shovel! As you dig the new hole throw the dirt into the old hole. They used to do that all the time when everyone had outhouses!!!
nsula_country ![]() Orange Level ![]() ![]() Joined: 10 Mar 2011 Location: NW Louisiana Points: 218 |
I like the tap, bolt, loctite method. I have done this before. Sometimes welding a hole can create more problems.
CT
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
Actually I just did that last week. I tapped out the hole to next size as stated before. I then took a grade 2 bolt and tightened the bolt into the last thread on the bolt as tight as I could get it without stripping the threads. I cut the bolt off on both sides of the 3/16 thick piece leaving the bolt about 1/16 high on both sides. I then placed the part on solid steel and pounded both sides down like a rivit with a ball peen hammer. (I peened both sides) This expands the bolt tight into the old hole. I then ground both sides smooth, center punched where the bolt needed to be and drilled a small pilot hole and then drilled it to size.
Edited by Dick L - 14 Jun 2011 at 8:18am |
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2259 |
I have welded holes shut and big ones I have welded bolts in as fillers and then cut them off and ground them flat..
I'm gonna try Dick's method the next time the ocassion arises!
