help with number identification eb4764
iwik View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iwik Quote  Post ReplyReply Direct Link To This Post Topic: help with number identification eb4764
    Posted: 17 Jul 2012 at 7:14pm
bought me an old tractor. but need help to identify it and the engine so I can get parts for it. chassis eb4764 engine r15060k
Edited by iwik - 17 Jul 2012 at 7:16pm
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2012 at 7:37pm
iwik  could used a little more info
like make model but will give you
a guess ed40  here is a site to help
other will help if you provide more
info
 http://www.tractordata.com/farm-tractors
/003/9/9/3996-allis-chalmers-ed40-engine.html
B:-)     Dnoym
iwik View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iwik Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2012 at 7:40pm
allis chalmers EB would guess 1945-1955?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2012 at 7:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2012 at 8:02pm
B Serial Numbers:
Location:On top of transmission case, behind shift lever. English-built models have an 'EB' serial number.
iwik View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iwik Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2012 at 8:03pm
1951: 4001 (EB)
1952: 6861 (EB)
so mine most be a 1951
now i need to identify the engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 6:47am
i think that they only used 3
different engine in the b tractor
Waukesha  Original engine,
used in 1937 on the first 96 tractors built
Allis-Chalmers BE vertical I-head
Second engine, used until 1943, SN 64500
Allis-Chalmers CE
Final engine, used from 1943 on, SN 64501
B:-)     Dnoym
iwik View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iwik Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 7:09am
i don't think its a original engine.
engine number is R15060K
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 7:29am
can you post a picture of it
and by the way welcome to
the forum
B:-)     Dnoym
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 8:07am
Allis-Chalmers CE
B:-)     Dnoym
Basically the same engine was used in an RC with an R in front of the numbers instead of the BE or CE. The R may have also been used in a power unit??????????
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 8:28am
I believe that would be the serial number of a 'B' assembled in the UK
an English B
Perhaps the UK guys will chime in ( when they get up !! )
Gary
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 8:45am
My book on the model "B" engine specifications-" 3.375" bore on British built tractors".
mdtractormechanic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdtractormechanic Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 8:58am
The R prefix is found on the 60H power units as on the RC. Later 60H models had a CR engine prefix.
Edited by mdtractormechanic - 18 Jul 2012 at 9:41am
Joe's 1939 Model WC, 1940 Model RC, 1944 & 1950 Model C's, B-125 PU
Dave Everett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Everett Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 12:45pm
English B 1950, first EB was EB4001 in November 1950, R motor is an english power unit from a combine or baler
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Everett Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 12:51pm
Also low compression kerosene pistons and manifold, but then all EBs were, there never was a gas burner, MOST parts are interchangeable with the US bs, but not all, such as the clutch and release assembly and front wheel hubs and bearings. the whole assembly has to be changed, not just parts......been there               got the T shirt.......
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 5:54pm
Anyone ever opened up the British "B's" to confirm the 3.375" bore??????? Standard bore at 3.250", correct??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Everett Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2012 at 1:47am
English EB bores are the same as the US CE motor, its all interchangeable 3-3/8
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdtractormechanic Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2012 at 1:38pm
3.25 is the BE (116) engine used till about mid 1942.
Edited by mdtractormechanic - 19 Jul 2012 at 1:39pm
