Help with D-series lights? |
JWV Fulton
Joined: 19 Mar 2017 Location: Fulton, MO Points: 24 |
Topic: Help with D-series lights?Posted: 08 Apr 2018 at 7:24am |
Does any one make or sell the bolts to mount the D-series fender headlights? I need 2 bolts to replace some rusty stripped out old ones. Thanks!
Scott B
Joined: 14 Sep 2013 Location: Kansas City Points: 1055 |
Posted: 08 Apr 2018 at 7:03pm |
I'm with you on needing these. So chiming in to follow the post
D17 Series 1
Allis B- 1939 Allis B- 1945 |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 08 Apr 2018 at 8:16pm |
I'll post a picture in a few days. I've managed to salvage a few. I think the bolt itself can still be found without the hole through it, so that is a good start. Check with local industrial suppliers. If they carry them, you would just have to drill a hole through them.
Brian Jasper co. Ia
Posted: 09 Apr 2018 at 8:51am |
I needed a couple headlight bolts once. I got the lowest grade bolt at the hardware store and drilled right down the center with a drill press.
Acdiesel
Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2592 |
Posted: 09 Apr 2018 at 10:47am |
A 1/2" plow bolt with a hole drilled down the center.
or a carriage bolt will work great too. I've used both. dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
