Help - Changing 7000 Hyd Fluid |
houchens ![]() Orange Level ![]() ![]() Joined: 29 Mar 2012 Location: Sunfish, Ky Points: 668 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Oct 2012 at 5:30pm |
Need help changing the hydraulic fluid in a 7000, just brought one home yesterday. Have the fluid and filter, I've already removed the filter and drained what oil out that would come out of the plug where the filter is. Where else do I need to drain, as this doesn't seem like nearly enough oil drained out?
Any help's appreciated! Thanks!
8050 200 7010 185x2 D17-IV D15IIx2 D14 WD45 Deutz Allis 6260 Gleaner Kx2 Gleaner K2 Diesel 2300 discx2 600 and 333 planters 2 AC wagons several AC plows/chisels Rotobalerx2 Other Misc AC Equipment
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21898 |
There is another drain plug behind the fuel tank that takes 1 1/8" wrench. The dipstick you are checking is for the differential, not the hydraulics. Fill the hydraulics behind the batteries and use sight glasses to check oil level.
