Heisler two barrel carb and manifold info
orangeone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeone Quote  Post ReplyReply Direct Link To This Post Topic: Heisler two barrel carb and manifold info
    Posted: 11 Feb 2015 at 7:38pm
I have a Heisler two barrel manifold for my AC and am in search of a carb for it any info will be a help thank you Andrew
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2015 at 8:38am
That's interesting. Never heard of a Heisler manifold before. What AC engine does that fit? And, what brand carburetor goes on that? Just curious...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2015 at 8:53am
I have one that was designed for a WC or WD. I no longer have the carb, which was two-barrels/two throttle butterflies, so it makes the manifold kind of useless. It was not for a WD45, as the carb hose was the smaller diameter. I think their goal was the increase the HP of a WD to try and match the WD45
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2015 at 9:01am
i never seen one like that mush be a proto or an  r&d part ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2015 at 11:32am
No. It was a go-fast part just like M&W pistons/sleeves.......Sherman overdrives, etc, etc. I'd sell my manifold for $50 if someone wants it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2015 at 12:38pm
that sure has me interested
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2015 at 2:49pm
Pictures?
1944 Allis C
1960 Allis D-17 LP
Steve Zidlicky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Zidlicky Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2015 at 7:23pm
Heisler made both manifolds and heads for 2 cylinder john deere's. they were for more power. the manifolds while still all one piece had the intake runners designed to run cooler thus more power from cooler fuel and the heads were "flat heads" for more compression.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeone Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2015 at 9:49pm
I would be interested in your manifold where are you located? please text or call me at 641 -352-0327 my name is Andrew and I am in central iowa and my e-mail is allischalmers53wd@yahoo.com
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2015 at 7:10pm
  heisler made lots of aftermarket parts-transmisson parts and kits-step up an down
