hd11e steer clutch questions |
butch1 ![]() Bronze Level ![]() Joined: 19 Jul 2025 Location: illinois Points: 3 |
![]() ![]() ![]() ![]() ![]() Posted: 17 hours 46 minutes ago at 8:55pm |
Hello all, has anyone used the steer clutch springs from general gear? I got my order of disks and springs Friday the replacements look like die springs the pressure checks @ 220lbs aprox on the springs but the 62 year oem rusty ones checked 250 to 285 @3 11/6 inch, oem spec shows 235 to 265 thats only 66% im concerned any input would be appreciated. the unit is a 62 or 63 hd11e.
sorry specs show 335to365 lbs
Ray54 ![]() Orange Level Access ![]() Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4729 |
In general General Gear gets good reviews. But If you have specs for springs and a way to test them it make sense to check. No matter how hard one tries most stuff comes from China.
I had a new to me 1950's Cat D6. Steering fine until it was not. Pull one steering clutch and you stopped. I want to say springs were less than 1/2 of spec. But my tester was not the greatest. Set a bathroom scale in my hydraulic press, pressed spring to what ever the length for spec was. Read what the bathroom scale read.
Tad Wicks ![]() Orange Level ![]() ![]() Joined: 27 Mar 2011 Location: Shandon, CA Points: 2174 |
That is certainly a substantial difference. I bought new ones at Fresno Tractor years back, might be worth a try.
gemdozer ![]() Orange Level ![]() Joined: 17 Sep 2009 Points: 1040 |
I am still have some stering cluch springs and I check this morning some spring wire are thin and some are complet round and need more pression
