Have to choke everytime clutch is let out |
Krazy Karl
Topic: Have to choke everytime clutch is let outPosted: 18 Dec 2016 at 10:02am |
Have a d17 that every time go to release the clutch have to choke the tractor to keep it running. This is even when tractor has been running awhile. Is there anything simple to adjust or change to get it to run without chokeing all the time
DougS
Posted: 18 Dec 2016 at 10:07am |
Does the tractor otherwise have power under a load without the choke?
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Posted: 18 Dec 2016 at 10:14am |
I had a 170 gas that did that. Finally figured out the main jet up inside the carb was loose and just floating in there.
ALLIS EXPRESS!
This year: |
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8627 |
Posted: 18 Dec 2016 at 10:39am |
Humm Could be a variety of things. But I think I would check the fuel system from one end to the other. Tank through carb.
If the carb has a plug on the bottom, I would check for good gas flow through the carb (not running). If that is good then the problem could be timing and or electrical? Let us know what you find on the fuel side first. Regards, Chris |
Krazy Karl
Posted: 18 Dec 2016 at 1:42pm |
Yea it seems good when pushing snow its just when changing direction and releasing clutch. Will have to check fuel flow and carb when little warmer out as today is -15
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8737 |
Posted: 18 Dec 2016 at 1:43pm |
Wrong mix somewhere.Don't know if idle circuit can be off enough to cause that.Some small engines can have that from idle circuit.
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 18 Dec 2016 at 1:48pm |
I was thinking the same thing with the mix running too lean I would guess I would almost bet some of the passages in the carb are plugged. I think I would pull the carb and clean it up really good checking the small passages with a wire. Carbs are sort of an art from if you ask me I ended up taking mine to someone local who is an old timer and knows how they cleaned them back in the day.
Rick
Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3695 |
Posted: 18 Dec 2016 at 2:22pm |
I've also had them where they had a tad of water in the gas and that makes them run sick! LOL! Could have ice throughout the line or carb. somewhere at that temp.. Rick
Gerald J.
Posted: 18 Dec 2016 at 4:04pm |
Lightly loaded, clutch pushed in, it mostly runs on the idle circuit as the governor closes the throttle a lot. Then when the load comes back the governor opens the throttle rapidly. Most carburetors have some sort of acceleration pump to enrich the mixture for that event because the carburetor tends to go lean right when you want it to produce a rapid increase in torque. Could be the acceleration pump not working, could be the idle mix is set way too lean, could be main jet partly plugged, could be all of those at the same time. I'd start by enriching the idle mix, that screw often adjusts air to the mix, so it gets richer by turning the screw in. There is an idle adjustment procedure, requires overriding the governor with the throttle closed, and adjusting the idle jet for maximum engine speed. If the governor has control it will hide the results of any changes in mixture, so just hold the throttle closed, I don't think you have to disconnect the governor rod.
Gerald J. |
HD6GTOM
Posted: 18 Dec 2016 at 6:40pm |
Might also want to check for vacume leak at the manifold.
Honey B
Joined: 28 Oct 2012 Location: Jasonville IN Points: 49 |
Posted: 18 Dec 2016 at 9:16pm |
I have a 48 Plymouth that did the same thing I went through the fuel system but did the same thing. My Grandpa said to replace the condensor I said no way but he was right again. Might try it.
MACK
Posted: 18 Dec 2016 at 9:32pm |
Open the main jet in front bottom of carburetor. Check timing. MACK
wayneIA
Joined: 17 Oct 2009 Location: Waverly, IA Points: 268 |
Posted: 19 Dec 2016 at 3:13am |
Like what HD6GTom said, check and make sure your manifold isn't warped. Not uncommon on the WD, WD-45 and D17's that the manifold will warp and allow a vacuum leak on the intake. If you have a local machine shop with a large belt sander, they can lay the manifold on it and level the ports again. Then slap on a fresh set of gaskets and should be ready to roll. When you push the clutch, the governor will virtually close the butterfly which creates a higher amount of vacuum in the manifold magnifying the leaning of the engine.
Butch(OH)
Posted: 19 Dec 2016 at 8:48am |
Like MACK said before you get any wrenches out adjust the main jet out a quarter turn at a time and see if it goes away. Extremely late ignition timing will cause similar problems and will often be accompanied by occasional belching out intake when a load is applied.
Edited by Butch(OH) - 19 Dec 2016 at 8:49am |
Kevin in WA
Joined: 08 Feb 2010 Location: Lynden, WA Points: 612 |
Posted: 19 Dec 2016 at 10:24am |
Also make sure the thermostat is good so the engine warms up properly.
Eldon (WA)
Posted: 19 Dec 2016 at 10:57am |
That is what I was doing with my 170 for 3 years. I would adjust it (I think it was like 1 1/2 turns out) and it would do fairly well for awhile then go out of adjustment. I finally took the time to remove it, stuck a small screwdriver in the hole and found the jet seat inside there was loose. Tightened it up and it ran like a new tractor.... Edited by Eldon (WA) - 19 Dec 2016 at 11:07am |
ALLIS EXPRESS!
This year: |
Brian G. NY
Posted: 19 Dec 2016 at 4:44pm |
I'm in agreement with Mack also.
I find it necessary to open the main jet about a quarter turn more in winter than summer. If I'm working it real hard in the winter and the temp gets well up into the green I sometimes set the main jet back.
pumpkinman
Joined: 20 Jul 2011 Location: S.E. Michigan Points: 252 |
Posted: 19 Dec 2016 at 5:24pm |
could be carberator iceing if its real cold look for frost on the intake manafold at the carb base use your propane torch to warm up the intake also 1 or 2 cans of drygas in the fuel tank
TedBuiskerN.IL.
Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
Posted: 19 Dec 2016 at 5:33pm |
I follow Mack's advice, but I go half a turn farther open in the winter. The colder air is denser, so more O2 molecules per volume of air, so fuel needs to be adjusted to compensate.
Chalmersbob
Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Posted: 20 Dec 2016 at 2:40am |
no acceleration pump in these carbs. Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Gerald J.
Posted: 20 Dec 2016 at 9:56am |
The for the transition between the idle and main jets, the fuel level in the float bowl needs to be higher so it runs richer in that transition.
Gerald J. |
Krazy Karl
Posted: 26 Dec 2016 at 7:46am |
Was able to go and look at it last week. End up adjusting the load screw some. And that seemed to help it out. Thanks for the help. This spring/summer got to get her tuned up. I know that need to do manifold gaskets as exhaust has a leak. And what your opinions on eletronic ignition.
Dan73
Posted: 26 Dec 2016 at 7:50am |
If you go electric ignition switch it to negative ground. I have one tractor with a positive ground kit that works and one that has eaten several positive ground kits. The negative ground kit is more robust.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24889 |
Posted: 26 Dec 2016 at 8:16am |
re: electronic ignition...
There's been a lot of comments about 'substandard' points so maybe you should go to EI, 12V neg ground. I am 'disappointed' that the EI units sold are not 'bullet proof'. Technically possible,only $2 in parts does that, but then they'd only sell you one.... While you upgrade put an alternator on it. I like the CS-130 series,small diameter so it looks better than the old clunky ones.. And naturally you'll install a 100% new wiring kit...for reliable,consistant, trouble free tractoring..... Jay |
