Got a Question |
SteveMaskey(MO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Wellsville, MO Points: 617 |
![]() ![]() ![]() ![]() ![]() Posted: 31 Dec 2011 at 3:41pm |
Will a 190 3pt. hitch work on a D17 IV? The 17 has a snap hitch and they want to change it to a 3pt.
Rick ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3697 |
Steve, I'm not sure about the 190 working on a D17 Series IV,but it will work on a D19. I do believe there is a difference,but I could check that for you tomorrow,if you want? I have a factory three point setup on a D19 and a snap coupler off a D17 Series IV that I could measure the rear lift housing and see if they would bolt up. I'll be in touch,Steve. Rick
Skyhighballoon(MO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Steve - won't bolt up as the rear housings are completely different. There may be some parts on the lift arms/lift links on a 190 that are the same but that's about it. 170/175/180/185 3 point will bolt right up. Mike
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
Mike...that's exactly what I was thinking. If I remember correctly,I checked all of this out 4-5 years ago and it didn't work then either! LOL! You guys have a Happy New Year!!! Rick
norm[ind] ![]() Orange Level ![]() Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
have 190 3 pt. for sale 1-800-254-3116 wrong section sorry
Thanks Rick and Mike for the information. Thats what I told him and just wanted to be sure I was correct. I know my brother tried to put a 180 3pt on a D19 and the top part worked but the bottom part would not bolt up. Thanks again. Steve
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21870 |
I've never done this, but always thought there was a possible way to make the wider (D19-190) hitch work on a narrow (D17-170-180) rearend housing. I believe you could manufacture two spacer plates one inch thick to mount to the rearend and then have a second set of holes to line up with the hitch itself. It would require some threaded holes in this plate and some countersunk holes for others. Only downside I can see is the hitch would be located one inch further rearwards from where it normally is, which wouldn't bother anything. Something to maybe consider ??
Jeff Z. NY ![]() Orange Level ![]() Joined: 11 Sep 2009 Points: 7326 |
As Posted:
Got a Question You too!!! My whole life is one big question. ![]() |
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
