Gleaner F3 Return elevator
lbr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lbr Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner F3 Return elevator
    Posted: 02 Oct 2019 at 11:35am
I just installed a new return elevator chain in our Gleaner F3. It is now catching on top just past the inspection door on top every so often and I have to turn the chain backward to free it up. This didn't happen until the new chain was installed. Is it recommended to run this chain tight or on the loose side. Thanks for your help
Bob
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2019 at 4:19pm
If you can't slide a chain roller back and forth at the sprocket, it is too tight. Loosen just enough so you can slide the roller back and forth by hand.
Wink
I am a Russian Bot
Super B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Super B Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2019 at 6:11pm
Look at the condition of your sprockets.
lbr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lbr Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2019 at 7:33pm
thanks, We got it going. We tighten it up some more and we ran a 2-4 acres without a issue. And we replace the sprocket and the chain at the same time. Thanks again for the replies.
Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2019 at 8:16pm
Your chain should be touching all of the lower sprocket,not hanging loose.
