Gleaner E unloading auger
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner E unloading auger
    Posted: 24 Sep 2020 at 2:10pm
I have had trouble swinging mine into place...I admit am older now...besides being unbalanced in its swing the pin doesn't want to line up....this is a 1964 and has no carrier in the auger tube for he shaft..and quite worn...appreciated any suggestions...Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2020 at 2:52pm
I imagine the hinge and hinge pin are worn, loose or bent.
Steve g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve g Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2020 at 7:28pm
Did that year not have carrier bearing. The E I have does have a carrier bearing holding up bin auger it appears to be intact but sheet metal that's its bolted to is gone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 9:17am
Mine is 1964 and no carrier bearing in the auger itself...hard to pull the auger overcenter and guide the parts together...Mark
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 6:10pm
On the later ones there was a ? Shaped rod that went through a hole and lifted the tube auger up to help get started on the drive. My 67 has one but my 64 doesn’t.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 6:43pm
Are you certain that there's no build up of grain dust in the "hinge" area ? We ran an "A"  and a straight "F" with that fool-proof unloading system with none of the issues your having, and sadly, the F was pretty much worn out front to back INCLUDING  the 'replacement' engine Wink
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 8:14pm
No, the E is a pain in the @## compared to other models. And the little hanger was not much help.         MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2020 at 7:56am
Been using a large wide putty knife to hold it up....thanks for all the imputs ..Mark
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2020 at 9:10am
Dad put a hand crank winch on the corner of the bin in place of the top brace pulled it around till it almot touched a big putty knifethen couple clicks its in place
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2020 at 10:59am
I have a 67 E and it's a little bit of a pain to get the auger swung out and on the drive. Probably because of 50+ years of service...
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2020 at 8:24pm
Park it headed down a steep Slope will help.           MACK
