Gleaner e retaining collar
Steve g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve g Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner e retaining collar
    Posted: 06 Oct 2020 at 4:45pm
trying to remove this retaining collar. The second hole appears to have something down in it with a dimple in it. The set screw is loose and for the last two months been spraying PB blaster over the complete unit.. i'm not sure if this is a dummy hole or after you set the setscrew that you punch that second hole to help secure the collar on the shaft
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 4:53pm
Your going to want to torch it off. Probably the bearing too. The second hole is to rotate the collar in the direction of rotation to lock the bearing to the shaft
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve g Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 4:59pm
Oh yes the gas hatchet works miracles.
robb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robb Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 4:59pm
The second hole is to lock and unlock the bearing to the shaft before tightening the set screw. Use a punch and hammer to unlock it and it should come off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve g Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 5:10pm
Now that makes sense because on one side of the hole it looks like it's been hit with something. Like a punch to lock it on The shaft . Thanks for that helpful idea will try it .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve g Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 6:27pm
You were exactly right. A punch and a hammer about four hits loosened up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve g Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 6:34pm
Can get collar to turn almost 1/4 turn loosely then hits a hard spot..
Just rusted up , more PB blaster, keep tapping it back and forth.
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 7:36pm
Loosen/remove set screw. As you turn the collar, note where the mid point is from left to right extremes. Once the collar is at mid point, pull it straight out. When you install the new bearing, put the lock ring on the bearing and use a punch to turn the collar and snug/tighten it on the bearing. Tighten the collar by turning in same direction of shaft rotation. To loosen collar, turn it in opposite direction of shaft rotation. Once you get your new bearing you'll be able to see better how they work. I usually end up torching the bearing off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 7:37pm
It’s a cam lock collar. In the center of the loose area it should slide off the end of the shaft.
I got a $100 bill that says the bearing is frozen to the shaft and your going to have to torch it off. Been there done that too many times. I don’t even try to loosen the set screw any more. 5 minutes with the torch and both bearing and lock collar are off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 8:08pm
Thats a simple one,, undo the carrier bolts -torch it off, clean it up, rub that shaft with fine sand paper, install the new bearing,, 1 hour job
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2020 at 5:32am
1 hour job only if you have a couple beers while shooting the bull with the neighbor..... telling the latest jokes.
Edited by Lonn - 07 Oct 2020 at 5:33am
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve g Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2020 at 9:31am
Thanks GOT IT   Sandpapered the shaft . When collar was loose just took a little pinch bar on each side and slowly worked it off the shaft . PB blaster works miracles,and this machine been sitting outside for 20 years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2020 at 12:05pm
An air chisel rattling the race helps loosen things up. I like to file the burr from last setscrew down. Helps with removal and installation.
