Gleaner E engine fitting 170?
Steve A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner E engine fitting 170?
    Posted: 21 Feb 2020 at 6:11pm
Would a Gleaner E engine be an easy swap with an early 170 engine? I realize they are both 226, and the governor setup would have to be switched.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2020 at 6:46pm
Easy swap and will probably be 4 HP short of your old engine. The serial number on the block will have the letter "M" or "Z" on the end.   M will be short on HP and Z will match your HP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2020 at 7:11pm
Thank you Doctor! I assumed that might be the case when I bought the 170, but it's good to get it confirmed.
