GLEANER COMBINE BRAKES
JFREED View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JFREED Quote  Post ReplyReply Direct Link To This Post Topic: GLEANER COMBINE BRAKES
    Posted: 11 Jan 2012 at 8:42pm
Can someone tell me what brake fluid goes into the master cylinders on a 1979 F2 Gleaner?  Is is some kind of hydraulic oil or DOT 3 brake fluid.    ~Thank you~
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2012 at 9:15pm
Maybe not the same, but I used DOT 3 brake fluid in the N6's. Always hated doing that job. Taking up the floor mat, and standing on your head to fill them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2012 at 9:34pm
Regular old DOT 3 fluid.
schwanman66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote schwanman66 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2012 at 9:40pm
Your lucky if your brakes work in your F2!  Ours never seemed to work in any of ours (C2, L, L2, or our L3)!  Of coarse with the hydro you didn't really need them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2012 at 9:47pm
HMMM! My 78 F2 will lock either wheel. Pretty handy spinning around on one wheel opening up corn fields.
Post Options Post Options   Thanks (0) Thanks(0)   Quote schwanman66 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2012 at 9:54pm
Have to agree, would be nice at times just like you said Steve!  I remember when we were picking corn with the C2, the rear end was so light with the corn head on that it would pick the back of the combine off the ground at times just pushing in the clutch!  Brakes would of made if even more fun!
1970 & 1971 190xt Series III's & 160
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2012 at 11:26pm
An F Gleaner has brakes???
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 2:13am
i never been in any kind of a combine...that had brakes!!
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 12:16pm
My F has great brakes, sometimes too great when you see the ground coming up to meet you, you learn to put the head down real quick!
Meanolallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meanolallis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2017 at 4:49pm
Has anyone ever used Non-detergent SAE 10 oil in the F2/F3 or have an opinion on that? I think that is what is called for in the 6000 series tractors and I'm pretty sure the Gleaner manuals don't specify a brake fluid. I'm thinking that SAE 10 oil might be easier on the paint and seals and maybe cheaper than DOT 3 brake fluid...
