GLEANER COMBINE BRAKES
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=43598
Printed Date: 04 Sep 2025 at 10:01pm Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: GLEANER COMBINE BRAKES
Posted By: JFREED
Subject: GLEANER COMBINE BRAKES
Date Posted: 11 Jan 2012 at 8:42pm
Can someone tell me what brake fluid goes into the master cylinders on a 1979 F2 Gleaner? Is is some kind of hydraulic oil or DOT 3 brake fluid. ~Thank you~
Posted By: Unit3
Date Posted: 11 Jan 2012 at 9:15pm
Maybe not the same, but I used DOT 3 brake fluid in the N6's. Always hated doing that job. Taking up the floor mat, and standing on your head to fill them.
Posted By: SteveM C/IL
Date Posted: 11 Jan 2012 at 9:34pm
Posted By: schwanman66
Date Posted: 11 Jan 2012 at 9:40pm
Your lucky if your brakes work in your F2! Ours never seemed to work in any of ours (C2, L, L2, or our L3)! Of coarse with the hydro you didn't really need them.
Date Posted: 11 Jan 2012 at 9:47pm
HMMM! My 78 F2 will lock either wheel. Pretty handy spinning around on one wheel opening up corn fields.
Date Posted: 11 Jan 2012 at 9:54pm
Have to agree, would be nice at times just like you said Steve! I remember when we were picking corn with the C2, the rear end was so light with the corn head on that it would pick the back of the combine off the ground at times just pushing in the clutch! Brakes would of made if even more fun!
------------- 1970 & 1971 190xt Series III's & 160
Posted By: TedBuiskerN.IL.
Date Posted: 11 Jan 2012 at 11:26pm
An F Gleaner has brakes???
------------- Most problems can be solved with the proper application of high explosives.
Posted By: SHAMELESS
Date Posted: 12 Jan 2012 at 2:13am
i never been in any kind of a combine...that had brakes!!
Posted By: John (C-IL)
Date Posted: 12 Jan 2012 at 12:16pm
My F has great brakes, sometimes too great when you see the ground coming up to meet you, you learn to put the head down real quick!
Posted By: Meanolallis
Date Posted: 28 Nov 2017 at 4:49pm
Has anyone ever used Non-detergent SAE 10 oil in the F2/F3 or have an opinion on that? I think that is what is called for in the 6000 series tractors and I'm pretty sure the Gleaner manuals don't specify a brake fluid. I'm thinking that SAE 10 oil might be easier on the paint and seals and maybe cheaper than DOT 3 brake fluid...
