Poor Man’s……….
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Poor Man’s……….
    Posted: 18 May 2025 at 2:51pm
car washing detergent?
The 1991 F-350 has taken a beating from the AZ and TX sun, although it is white the ‘shine’ appears to quite dull, almost a ‘flat white’ look. What would a good household cleaner that may help, TIA.
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2025 at 6:04pm
Be happy it isn't rust brown or gone altogether and the same color as the background on the other side, like they all are here.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2025 at 6:07pm
Most people likely to say you should never use household cleaners on vehicles. Too harsh on the paint. That said, when we was kids, Dad had us wash the car with Cheer laundry soap. It was a powder and kinda gritty. Cleaned real well
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2025 at 6:12pm
dont think the type of soap is gong to make any difference... Probably needs to be POLISHED to get the DULL HAZE off... then a good coat of WAX..... if REAL bad, you start with rubbing compound , but i would try the POLISH and see how well it removes the  oxide surface..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2025 at 6:16pm
What Is a Rubbing Compound?
A rubbing compound is a gritty substance that levels the paint on a car’s surface. Think of it as fine sandpaper in a paste form designed to remove the outermost layer of paint. Rubbing compound comes in handy when dealing with scratches, oxidation, and other surface defects that affect the outer layer of the car’s clear coat. It’s more abrasive than its polishing counterpart, making it the go-to choice for correcting significant imperfections in a car’s paint job.
What Are Polishing Compounds?
Conversely, polishing compounds are less abrasive and aim to bring out the car’s natural shine after dealing with its imperfections. Their primary purpose is to smooth out the finer marks that a rubbing compound might leave behind. A polishing compound works to refine the work of the rubbing compound, enhancing the paint’s luster and creating a glossy finish. It’s the final touch in the detailing process, helping vehicles look their best before hitting the showroom floor or returning to a customer.
Differences Between the Two
The difference between rubbing and polishing compounds lies mainly in their level of abrasiveness and intended purpose. A rubbing compound acts as a corrector, while a polishing compound serves as a finisher. Rubbing compounds will eliminate deep scratches and oxidation, but they can leave swirl marks or micro-scratches due to their abrasive nature. That’s where polishing compounds come into play, removing those finer imperfections and giving the car a mirror-like finish.
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2025 at 4:47am
WD-40 restores a temporary shine to oxidized paint, as does vegetable oil for faded black plastics/rubber. Not a true fix but does minimize small scratches and lacquer peel well.
I have heard of folk wiping on a thin layer of wood varnish to clean paint as a "less temporary" "hack" too but the only real, lasting thing is to cut/buff/polish & wax. *(and then keep it washed and waxed every damn week thereafter!)
That brings other issues into play though as you're removing paint this way, although microscopic it adds up over years & who has the time to keep up on the wash/wax religiously? so the cut/buff inevitably needs a repeat now and again, then you end up with the "patina"...
Personally I like the patina look, it's not a new machine it's had a life so who cares if the paint's rubbed through? If it's a new truck you're looking for then you can respray it as part of the restoration, if you want her to scrub up for going to town once in a while then give 'er a wipe down with an oily rag and have done with it Wink
Just my 0.02 YMMV
Edited by ekjdm14 - 19 May 2025 at 4:53am
Stuck Farmer
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2025 at 6:38am
Did the old used car salesman trick to my '86 GMC last summer. Rubbed it down with tranny fluid. Used about 2 cups to do the whole truck. You can see the before and after in the close up picture. I washed it with some Zep citrus degreaser first to get the oxidation off.
Neighbor did his '64 Ford pickup with a product called Flood Penatrol. Watched some videos online of guys doing it. They say it lasts about one year. Works kind of like a clear coat.
Edited by truckerfarmer - 19 May 2025 at 6:42am
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2025 at 7:58am
Isn't that going to make it a dust collector ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2025 at 9:47pm
It did catch a little for the first week. Wipe it on with one rag, buff it with a clean rag. "Wax on, wax off".
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2025 at 10:08pm
Tide laundry detergent and dishwashing soap in warm water make a very good car wash solution. High foam and good degreasing are key with a clean rinse.
If talking "old, or aged" paint, I always liked 3M "Super Duty" rubbing compound and 3M "Microfine" finishing compound after a quick color sand with 1500 grit wet or dry paper in the early days, and 1500 grit dry on an air sander with a foam interface pad in the later days. Always 3M, or Lake County pure wool buffing and polishing pads on a Milwaukee, or Sioux brand variable speed buffer/polisher. You can use foam pads also but they perform much better on fresh rather than aged paint.
Lemon "Pledge" furniture polish is an excellent automotive gloss enhancer for the car show circuit.
Edited by Codger - 19 May 2025 at 10:08pm
That's All Folks!
This page was generated in 0.083 seconds.
