Need HD5 flywheel clutch shifting sleeve
dyno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dyno Quote  Post ReplyReply Direct Link To This Post Topic: Need HD5 flywheel clutch shifting sleeve
    Posted: 16 Dec 2012 at 9:54pm
Hi,
I'm looking for p/n 077697 shifting sleeve for my HD5 crawler. This is from a Rockford style clutch. An assembly complete with throw out bearing (073647) and carrier (078052) would be great.
Thanks,
dyno
208-859-9082
Edited by dyno - 16 Dec 2012 at 9:56pm
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2012 at 8:35am
General Gear has them
http://www.tpaktopc.net/achd6strcltch.htm
dyno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dyno Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2012 at 10:00am
Unfortunately, the sleeves at General Gear are for an Auburn clutch. Mine is a Rockford.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2012 at 7:18pm
I made my own sleeve from a brass bushing i machined to fit . I may have a yoke but unsure and I know the bushing would be worn .
 The bushing wears out fast if the engine is left running with the transmission in gear and clutch disengaged.
 This is why when tractor is setting , put transmission in Neutral and engage master clutch so transmission turns.
 If you replace the bearing use a sealed bearing and no need to grease it then - that is what I did on mine along with the pilot bearing - sealed pre-greased bearing .
dyno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dyno Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2012 at 7:35pm
Yes, I have thought about trying to somehow repair the sleeve. the I.D. is really worn, so bad that the sleeve portion that had the bearing retaining snap ring was completely worn off. Now the bearing slips off the sleeve without the snap ring. I just don't know if there's a way to add a new sleeve portion to the 3 eared portion of the casting.
ac_sd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_sd Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2012 at 11:44pm
I might have one, I'll look tomorrow.....
dyno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dyno Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2012 at 8:42am
If I can't find a good used sleeve, I may have to have one made like Coke. Does anyone know what kind of clearance there is between the sleeve and the input shaft? Mine is excessively worn.
Also, I replaced the 3 cams inside the pressure plate with ones I got from Hector. The replacements didn't have grease fittings on them like my old ones did. Hopefully this won't be a problem as I don't use the machine very often.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2012 at 11:29am
I do not remember what I used for clearance it was - I need to replace this - I have this brass bushing i removed from a machine at work - if I turn down outside to fit into yoke and then bore it to fit over the shaft - yep tat is about the right size - couple thousands more - dang seems to loose now should have left it as it was - it works !
dyno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dyno Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2013 at 7:42pm
Looks like I'm going to make a new sleeve and press it in the hub.  I priced a piece of round stock brass and it was 175.00.
Do you think I could make one out of steel and expect it to wear OK?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2013 at 8:16pm
dont use a steel one.  dad had one made to sleeve the clutch on our old HD10W and it galled and siezed in about 5 min. yes it was greased.   Had a brass one made to same specs... still running
dyno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dyno Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2013 at 8:28pm
Thanks. Answers the question!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2013 at 6:56am
Don't use brass. Use bearing bronze. Bronze bushings are available from a bearing supplier I have also seen bearing bronze on eBay. You may have to machine the O.D. & I.D. but it should be less expensive than buying bar stock. Yes everything is getting more expensive.
dyno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dyno Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2013 at 8:09am
Ok I will look into some bronze stock. It looked like the original sleeve was made of brass.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2013 at 5:54pm
Bearing bronz or oil-lite bushings might be found - takes some hunting - I just happened to have the brass bearing from a machine i serviced (a scrubbing machine for aircraft panels) and the brass stock worked great. Been in my HD5 for 8 years now .
 I might have the cast housing in my extra parts but I know the inside bushing is shot in the one i might have.
This page was generated in 0.104 seconds.
