wd45 orchard - exhaust options
59f100292 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 59f100292 Quote  Post ReplyReply Direct Link To This Post Topic: wd45 orchard - exhaust options
    Posted: 04 Jun 2017 at 9:11pm
i'm tired of replacing the exhaust on a standard wd-45 due to trees damaging it while mowing.  Was there such a thing as a wd-45 orchard?   Are there any options for a re-routed wd-45 manifold/exhaust that flows lower/ doesn't exit through the hood?
Edited by 59f100292 - 04 Jun 2017 at 9:11pm
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2017 at 9:17pm
sounds like trimming the trees would be the simple solution...just saying
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2017 at 9:29pm
No such thing.  You sit pretty high up, so you would be getting branches in your face too.
Not to sound like a jack ass, but I would trim the trees too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 59f100292 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2017 at 9:56pm
fooling with the tractor is more fun than trimming trees, and i can dodge the branches.
But anyhow, i wasn't aware of an orchard wd-45, and it sounds like I was right.  Figured I'd ask.
Edited by 59f100292 - 04 Jun 2017 at 9:57pm
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2017 at 8:39am
What about a wc manifold that comes out the side. I have a Wd that has the regular muffler but it has the plate on the manifold for the little short pipe that comes out the side
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2017 at 10:02am
Send me your email and I"ll send some pictures your way that might be helpful
Can't fix stupid
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2017 at 11:11am
An apple orchard near me had a WD-45 with these full orchard style fenders on it. That was pretty much all it had that was different. Don't know if it was an official "orchard" tractor. I know where it is sitting, rotting away. The current owner is bull-headed and won't let go of it.
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 59f100292 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2017 at 2:04pm
This is a good Idea.  the WC and WD dont have the same bolt and port pattern do they? would a WC manifold fit?
Steve Bright View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Bright Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2017 at 2:18pm
Be simple to have a pipe bent to go towards the ground with a shorter muffler or just leave it as a straight pipe. Very little creativity should fix your problem.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2017 at 3:48pm
On some tractors where they had a similar problem we got flexable exhaust pipe and piped it down the side and out the back with a muffler there if desired.
Worked fine for us.
Good Luck!
Bill Long
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2017 at 4:04pm
I use my D-17 for mowing around a lot of "scrub" apple trees on my property and I solved the problem you're having by using scrap pipes and resonators to make this.
Works well and sounds good too!
Charles (KY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charles (KY) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2017 at 5:13pm
The George Nesbitt auction has a WF Orchard advertised.  I got a list of items with color pictures in the mail today.  I imagine the Gone Farming website probably has the pictures.
