Stuck Clutch
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Stuck Clutch
    Posted: 30 Apr 2017 at 7:53pm
I last used my D10 last October and then winterized it and put it in the shed. Got it out today but the clutch does not disengage.
What would make it stick?
I can see the clutch fingers moving in but that is it. What can I try?
I tried hitting the brakes with clutch in.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 9:02pm
Rust,mouse pee, or oil. If you can press the pedal; down, and hold it with tying it down, might pry the disc from flywheel with big flat screwdriver. HTH Tracy
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 9:04pm
Split it.     MACK
johnkc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnkc Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 9:24pm
here's my story on a stuck disc. 1950 Ford F2, drove it quite a bit with the clutch pedal pushed down and it would not pop loose. so I took the transmission out and removed the pressure plate and as soon as I started prying the disc from the flywheel it just fell off.
Wish I would have done what Tracy suggests. but it did give me a chance to inspect/clean everything.
I support the development of hybrid automobiles and alternative fuels as I need DIESEL fuel for my ALLIS CHALMERS!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 6:53am
Issue is resolved.
Strapped the clutch down, took a long flat blade and tried to wiggle it. No-Go
Put it against a little bump and tapped it and it came free as Willy.
Too simple...or I got lucky.
Charlie
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 7:36am
We have a 325hp steiger that came to us with a stuck clutch. We hooked up a chisel plow to my 7045 and then used a heavy chain to tie the tractors together. Dad drove the steiger with the clutch held down and I rode the 7045 and turned and raised the mounted chisel at the ends. We went over several acres before it broke loose but hasn't caused any trouble in close to 10 years since and a lot easier than a split. Sometimes you get lucky!
