Belly grader blade for D17
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Topic: Belly grader blade for D17
    Posted: 14 Mar 2017 at 8:32pm
Hey- anybody have pictures of a belly mount grader blade mounted under a D-17? I need something that'll flatten and grade better, and figuring I'll be fabricating it, but could use some examples...
Ross D. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 2:11pm
Hi.   In Aug. , 2008, at the A C show in Portland In., there was an open stationed 190 XP on display with an underslung grader blade assembly. Boy-o-boy, was it nice. Unfortunately, I can not find my pictures from that show. Perhaps someone else may have a picture of it. The gentleman who displayed it said that it belonged to his son and that he used it in the landscaping business. I think they were located to the north of Portland ( towards Ft. Wayne ).   Ross D.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 11:38pm
I'm curious why a snap coupler blade won't work?  One in good working order can be adjusted to about any angle you could want. They are heavy enough to dig deep, and with good hydraulics you can put it at any height to level off.  Just going thru my mind what all you could need to grade.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2017 at 1:11am
I'm looking for one in the belly, because the blade I have behind (or any blade behind) will dig IN when the front wheels climb up over a lump, and when falling down the other side, drop dirt on level ground.
I want to knock the high spots down as they pass between the front and rear axles.
I also want to be able to lean and swing the blade to use it for grading, like a speed maintainer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2017 at 9:42am
Hi Dave.   I like grading with the snap coupled grader blade; but, understand your comments on the frustration that you encounter. Here is a picture of a possible solution. If you could find a nice 'D' grader, I am sure you would enjoy experience. They do a good job and are a lot of fun to operate. This picture is of my 'D Special', with Calvin Schmidt grading Justin Biebers laneway in Stratford, Ontario.   Ross D.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2017 at 10:40am
And a D grader, late models, at least, use same motor, as a d-17...Wink
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2017 at 10:51am
how much room and money you gotLOL
here's a cheep grader (in my book).
 1
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2017 at 11:13am
That grader looks like it'd be a lot of fun to operate - I could use it on my lane! I can just hear my wife's response, though: "You bought WHAT??!!??"
Dave
WC, CA, D14, WD45
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2017 at 2:43pm
Dave, Maybe more practical than the HD-41 that was for sale in central Mass a few years ago. Bob@allidowneast
I used to think I was indecisive, but now I'm not sure.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2017 at 3:22pm
Make google your friend.
Click me
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2017 at 6:32pm
Did you see in the link Stan put up, grader Greg, it's a stretched out 700 series garden tractor with two rear drives. Interesting looking
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 9:12pm
SEEN THIS ON C.L.
 1
D15 SER.2 DIESEL
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 9:22pm
[TUBE]ZMXJvBZC52Q[/TUBE]
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 11:23pm
Use the idea that Farmall cub uses on their under blade!----simple made and does nice work!---I have one under one of my cubs right now.
You will do good with the under mount!
Grader in the above pic. looks like the BD-3 that I once had! ---DETROIT  3-71 engine!----I also had an Allis 45, it had the 516 engine in it---now thats a hoggin machine!!! LOL!!!  thanks; ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2017 at 8:56pm
PICTURES, PICTURES!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2017 at 10:29pm
Ya want pictures of my cub setup???---- Will gittum tomorrow and get them posted up for you.---It's an idea that could be adapted to any size blade or any color tractor.---Just scale it up to whatever size you need! thanks; ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 8:07pm
Took some pics of the cub blade between rains!
Here is one from the front, it gives a fairly good view of how its made and hooked to the tractor.---got another one from the back.
Finally got p-bucket to give me the pix.!!!
 thanks; ac fleet
Edited by ac fleet - 27 Mar 2017 at 8:44pm
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 9:33pm
I have an early D grader that I'm trying to sell. The engine is tight, needs tires.. It may be easier to put a blade on your 17. :).
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 6:48am
Wow, Fleet- that's a cool setup... yes, simple, and perhaps a little on the lightweight side, but for a Cub, that's to be expected.
Some variety of that was kinda what I had in mind. The hydraulic version above looked right, but the pictures were a bit small for details.
A Grader... yeah, aside from the long wheelbase maneuverability, it'd be nice. I'm the kind of guy that'd have one just because I could, but it wouldn't be the optimal worker for what I'll be working down... but hey... more pictures!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 6:49am
Charlie- for some silly reason, I can't get your video link to do anything but turn blank... can you re-post it as text?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 8:31am
Thanks for the pics Sonny!  Gives me a couple of ideas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 11:36pm
Ted!---You could use this as an idea to work from!---Just scale it up to whatever weight your tractor needs!---the idea can be adapted to any color or size tractor.
Nother' idea I have is to start with this STYLE setup,---THEN add a long cylinder on each side for seperate control of the blade---- angle could also be a cylinder on a third valve! ----I got all kinds of ideas!!! LOL!!!!
If the cub had aux. hyd. ( which they don't) I would put each side on a valve/cylinder to control the blade!---for its size it does great job the way it is, just gotta take light cuts!  thanks; ac fleet
This page was generated in 0.088 seconds.
