433I valve clearance
Chad S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad S Quote  Post ReplyReply Direct Link To This Post Topic: 433I valve clearance
    Posted: 30 Nov 2016 at 9:49pm
I need to adjust the valves on my repowered 170 but I don't have a manual for this engine. Think it came out of an F2. Can anyone tell me what they should be set at?
Ok don't know how to rotate pic from my phone.
Edited by Chad S - 30 Nov 2016 at 9:50pm
36 WC,41 WC,53 WD45,57 D14,65 D21,68 XT,72 XT,81 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 10:43pm
.017" COLD intake and exhaust.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 8:07am
Now that is how the 170/175 should have been built from the start! Sad that they could buy an outside sourced engine more cost effective than their own engine! Though the 2200(200 cid)wasn't made popular until they revised it for the 6000 series.
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 10:29am
Nice tractor!! Always wanted to do that swap on a 170/175! Tell use more about it.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad S Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 12:45pm
Thanks DrAllis.
peterson. Tractor was a gas. We used a 190 fly wheel and clutch. Fabricated an adapter of 1 3/8 in. to space engine out for the longer input shaft and had an adapter made for the front HYD pump drive. And the rest was just intake and radiator plumbing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad S Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 12:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad S Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 12:49pm
