New owner of a 7060
4267060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4267060 Quote  Post ReplyReply Direct Link To This Post Topic: New owner of a 7060
    Posted: 18 Apr 2017 at 6:18pm
Hey guys new to the allis world with the purchase of a 7060 maroon belly doing regular maintenance and was going to change all the filters and got to the powershift filter which appears to be a canister type on the rear end and was wondering if it screws off or what? Thanks!
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2017 at 8:05pm
It is a messy operation. Unscrew the long bolt that goes up through the can. It is spring loaded, so when it unscrews at the last, it might jump down at you. There is a large O ring around the top and should be one at the bottom. The most important thing is a plastic part in the top of the filter. It has magnets in the ears. (Watch close how the plastic comes out. It has two ears that have to go up into holes. Make sure the ears are in their holes when going back together or you will break the ears off. If you should break this part, you wouldn't be the first.) Clean the magnets and put it back together.
Edited by Unit3 - 18 Apr 2017 at 8:09pm
210Postin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2017 at 9:18pm
You have the small filter iam guessing about six or seven inches long it unscrews off
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4267060 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2017 at 9:35pm
This what I'm dealing with, not seeing a bolt running through it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 5:01am
Yes that is what I thought you have, the bottom spins off  tell them you have an early tractor lot smaller filter than the later ones
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 5:12am
welcome to the forum and the allis world.  Lotta good folks on here so don't be afraid to ask.  good luck. dt
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 11:47am
IF you changed the 'belly' filters - LH and RH make sure you pulled the plugs out of the ends of the filters and put them in the new ones....  the...921 and ,,,922 elements.
Also look for the bypass filter element for the engine behind the engine - most remove it and plug the lines..change the oil every 100 hours then is the general recommendation. 70269842 is the pn for early sn ps tranny filters.
This page was generated in 0.039 seconds.
