Will a F & H 161 Weight Fit My WC?
AC7040 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7040 Quote  Post ReplyReply Direct Link To This Post Topic: Will a F & H 161 Weight Fit My WC?
    Posted: 13 Mar 2017 at 1:16pm
Needing some help. Auction coming up some F&H 161 weights and I'm curious if they will fit the rims on my WC (in the photo). I've read some past topics that for the spoke rims the F&H 161 is the 'inner' weight and the 162 is the 'outer' weight. I believe the 2 holes on the rim are 18 inches apart. So not sure how they would work with these rims. Installed some brand new FireStones' without fluid and she's a little light in the rear end for plowing Thanks!
1953-WD45, 1949-G, 1950s Snap-Coupler All-Crop Drill, 1956 Roto-Baler, 1945 All Crop 60, Snap Coupler Subsoiler, Plow, Gleaner F, 505 wagon
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2017 at 1:20pm
Yes, the 161 is the inner or starter weight and the 162 is the outer or add on weights for the spoked and stamped wheels. The 161 is not used on the casted centers.
Edited by DennisA (IL) - 13 Mar 2017 at 1:25pm
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2017 at 6:37pm
Just fill the rears up with windshield washer fluid and be done with it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7040 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 7:33am
Thanks for info DennisA! Never thought of that CTucker! Wonder how many gallons I would need or if I could buy it in bulk hummm....
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 7:40am
Here is a chart that shows about how many gallons fit in given tire sizes by rim guard. You will have to find out what washer fluid weighs per gallon to see how to weight compares to rim guard.
Gallon Tables
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 9:56am
Then start saving money to buy new rimsLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 11:04am
 Calcium chloride took 50 years to rot out a rim. The windshield washer fluid will NEVER rot a rim Wacko
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 11:09am
Personally I like weights costs a lot less to have the tires changed when there is no fluid plus the wheels are a whole lot easier to handle.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 11:33am
I'm starting to go back to wanting fluid. I spent about $400 for 3 sets of weights for my WD45 + paint and bolts. Even with 3 sets I don't have quite as much weight as fluid would make. If you're light plowing, only adding 250 lbs won't be like night and day.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 12:20pm
Center to center measures 14.5 inches on F&H weights. I have them on my WD45 and Dad's 185.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 12:28pm
I put calcium in all rear tractor tires. I have never had a leaking tube or valve stem. Just do simple maintenance of replacing the core once every two years.
I also try to add wheel weights as well. I like my AC's but they all have more power than traction. Per Allis Chalmers, operators are to add weight until a maximum of 5% slippage is obtained. Allis also stated that adding weight should start with adding fluid first as fluid didn't add as much wear to the mechanics of the tractor.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 1:15pm
I have a 7045 with 20.8-38" tires. Each tire will hold more than 1500 pounds of calcium. To equal this amount of weight with wheel weights I would need to add over ten per side. That is just not practical. Calcium is around 14 pounds per gallon and washer fluid will be around 8 pounds per gallon. Not telling you what you should do just giving you a few things to think about. If you plan on using the tractor for pulling plows etc. you need weight.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7040 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 1:26pm
Thank you all for the help! I was able to pull a 2 bottom 'little genius' this past year pretty decent in regards to slippage. I think having brand new tires really helped. I used to have fluid in my WD45 rims and they started to eat out so I was kinda against fluid in all rims and looking towards going with weights instead. I guess I'll add a couple weights and see once how it goes, may at the end of the day have to install fluid.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 1:33pm
Though if you go to any tractor tire manufacturer's web page they all poo poo fluid. They all want weights used and used to proportion the weight to a certain ratio. Something like 65/35 back to front. I don't remember the exact ratio.
