WC Rods
khoney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote khoney Quote  Post ReplyReply Direct Link To This Post Topic: WC Rods
    Posted: 28 May 2025 at 3:20pm
I am putting new rings on a WC and when putting back together I see there is no offset on rod too bearing.  Does that mean they can be installed either way or is there a right and wrong ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2025 at 4:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2025 at 4:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2025 at 6:07pm
You've got to get the piston pins positioned correctly or you will have a groove cut into the sleeve from the end of the piston pin dragging !!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote khoney Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2025 at 10:07pm
Thank you gentlemen, that is what I needed.
