Thanks but had enough /it's real mechanic time
Rod Yowell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod Yowell Quote  Post ReplyReply Direct Link To This Post Topic: Thanks but had enough /it's real mechanic time
    Posted: 25 Jun 2012 at 12:01pm
Thanks to all you fellows that tried to help me solve my hydraulic problem on my WD45 but I have  had enough. After taking the pump off 4 times, taking it apart, cleaning it, putting it back on 4 times, the results are the same.  It is going to take someone smarter than me to get the hydraulic cylinders to work. I am taking it to a tractor mechanic and let them deal with it. "A man has got to know his limitations." Thanks guys for all your help.
Socialism is the Philosophy of Failure, the Creed of Ignorance, and the Gospel of Envy
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2012 at 2:02pm
Well, let us know what you come up with
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2012 at 2:41pm
Rod - I'd come over and help but I'm headed out on vacation tomorrow.  I'd ship it to Don(MO) rather than take it some place locally that's not familiar with old AC's.  Also, make sure you have the control valve set correctly if you haven't already (you probably have).
Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2012 at 5:03pm
Just had one apart last week. Pump took about 2hrs to disassemble , clean and put back together. Some years ago I posted the pics like in an exploded view. Here they are again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2012 at 5:07pm
Most of these pumps I see have alot of linkage and lever damage. A real good cleaning and maybe even sandblasting could be in order before any disassembly occurs.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2012 at 5:08pm
couple years ago my lift arms would go up fine but would just barely settle and stop halfway when going down, I personally knew a mechanic at the local AGCO dealer and he took the pump and rebuilt it. turned out when I had the top part off a few years ago I lost the little detent ball and when he rebuilt it from an old parts pump he noticed the missing piece, works perfect now. sometimes you need to compare it to a working pump before the problem is evident. good luck
Edited by Bill_MN - 25 Jun 2012 at 5:09pm
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2012 at 7:21pm
I hear ya! Sometimes you just have to walk away and let someone else figure it out. Otherwise, obsession sets in...
