like a rifle going off
cobra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cobra Quote  Post ReplyReply Direct Link To This Post Topic: like a rifle going off
    Posted: 03 Feb 2012 at 2:29pm
did a complete tune up on my d15 series II. points,plugs ,wires, cap, rotor button, condenser. tractor started backfiring like a rife going off. checked timing-ok checked point gap-ok checked firing order-ok.put old condenser back in and it worked perfect. blew snow for an hour. went to use tractor today and started  backfiring again. i assme its the condenser again.why would it blow two condensers or could it be something else. need help   thanks  smitty
Edited by cobra - 03 Feb 2012 at 2:32pm
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2012 at 3:53pm
Make sure your points are clean and the cap is dry inside!
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2012 at 4:26pm
I would guess that it has nothing to do with your condenser. Sounds to me like the advance is sticking/ not moving as it should.  That or the shaft is sloppy in its bearing.
You can take hold of the rotor and see how easy it will moves the advance if at all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 10:18am
Could be a bad spark plug. A misfiring plug will allow unburned fuel to enter the muffler and ignite making the explosion. Combustion is supposed to take place in the cylinder, not the muffler... LOL!
Steve@B&B
