D17 range selector
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Topic: D17 range selector
    Posted: 28 Jul 2014 at 10:01am
I've ordered the books, but they are not here yet.  The range selector looks like it should have a latch and latch button.  Mine doesn't.  lever snaps into high and low.  What am I missing?
nevans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nevans Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2014 at 10:38am
on the square plate there should be a arm with some notches to hold in place the lever Niel
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2014 at 12:33pm
The button is really on for Neutral. Hi and low is not held into place by it.
Charlie
Gary(OR) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(OR) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2014 at 4:12pm
There's a rod and spring that goes inside the lever with a button on top and a block and pin on the bottom. The pin engages in the arm (quadrant)mounted on the tractor. I should have all that stuff off my parts tractor if you're interested....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2014 at 5:25pm
Would the parts from a D14 be the same?  Gary, PM me a price.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(OR) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2014 at 2:52am
Don't know about the D14, but seems possible. I wonder if the control lever is the same length ?
I can only find the rod (with button) and the spring. Missing the lower block and pin. Sorry about that.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2014 at 10:07pm
The D14 lever is the same length, so parts from it will fit.  The one on your D17 was still being used on 175s in 1979!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2014 at 7:04pm
Wow,  always great information comes from Ontario.  Thanks Myron!!
