removing throat and header on R62
BearcatnorthMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BearcatnorthMN Quote  Post ReplyReply Direct Link To This Post Topic: removing throat and header on R62
    Posted: 27 Sep 2012 at 6:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote BearcatnorthMN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 6:47am
does anyone have step by step instructions on how to remove the throat and header on a R62 combine.  We sucked up a shovel from a cultivator and broke chains and slats on conveyor to grain compartment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 6:56am
You sure don't have to remove the feederhouse (throat) to replace either front or rear feed chains. Removing the header ?? should be a five minute job....
Post Options Post Options   Thanks (0) Thanks(0)   Quote BearcatnorthMN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 7:13am
was told we have to remove the throat and header in one piece by local dealer.  It is the rear chains and slats that need tlc.  The ones that go up to the grain bin.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BearcatnorthMN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 7:19am
I am just helping the guy get his beans out so am a rookie to the service on the combine.  Told him I would try to get some info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BearcatnorthMN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 7:20am
we are in the grain bin looking down at the chains that are broken and the slats that are bent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 7:36am
Open the double screen doors underneath the transmission. Then crawl inside and open the bottom door to the rear feed chain floor to gain access to the chain and slats. Find a guy who isn't over 200 lbs to do this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BearcatnorthMN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 8:40pm
Ah  Ha  will do and thanks Doc.....
