Help - Changing 7000 Hyd Fluid
houchens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote houchens Quote  Post ReplyReply Direct Link To This Post Topic: Help - Changing 7000 Hyd Fluid
    Posted: 07 Oct 2012 at 5:30pm
Need help changing the hydraulic fluid in a 7000, just brought one home yesterday. Have the fluid and filter, I've already removed the filter and drained what oil out that would come out of the plug where the filter is. Where else do I need to drain, as this doesn't seem like nearly enough oil drained out?
When I check the level on the dipstick at the back of the tractor, it's still full.. So I'd assume I need to do something to drain it out? Haven't worked on these series of tractors before, looks like I'm going to have to invest in a manual..
Any help's appreciated! Thanks!
8050 200 7010 185x2 D17-IV D15IIx2 D14 WD45 Deutz Allis 6260 Gleaner Kx2 Gleaner K2 Diesel 2300 discx2 600 and 333 planters 2 AC wagons several AC plows/chisels Rotobalerx2 Other Misc AC Equipment
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2012 at 8:39pm
There is another drain plug behind the fuel tank that takes 1 1/8" wrench. The dipstick you are checking is for the differential, not the hydraulics. Fill the hydraulics behind the batteries and use sight glasses to check oil level.
