WD 45
pssilseth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pssilseth Quote  Post ReplyReply Direct Link To This Post Topic: WD 45
    Posted: 16 Mar 2012 at 8:47pm
Do you know if the shaft that the hand clutch rides on is threaded into the casing or is it a solid piece? (Bought this old tractor in much worse condition than I could have ever imagined.) This shaft was increased in diameter by welding on and then ground down, and now handle is sloppy. So can the shaft be replaced?
Does anyone know where to get info on side delivery rakes/roll-r-bar rake? I was given a rake and it needs a little work, but we can not figure out the manufacturer. If I put a couple pictures on here could someone point me in a direction?
Thanks for any thing you can do, I will be asking a lot more in the future.
Paul
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 10:11pm
The pin is pressed into housing. Some come out easy some are tight.  MACK
David G. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David G. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 11:04pm
Put some pics on here, somebody can surely figure it out and get you pointed in the right direction.
