Took some pictures
Dave in il View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Topic: Took some pictures
    Posted: 19 Apr 2012 at 11:11pm
Took some pictures the other day
The 200 and a parts WD we're taking the rear tires off for the WD45
The 8070 waiting to go to the field.
92 IH 9400 and a 99 IH 9200.
My 88 F350 4WD ressurected just in time for planting.
Ready to fill the planter
What wouldn't fit on the truck.
Every year it takes me a little longer to fill this thing each time.
Not sure what the heck this is. Bulington Northern & Santa Fe railroad goes thru the middle of the section. This rig said Norfolk & Western. I think it might be a dynomometer car.
AGCO My Allis Gleaner Company
Larrywdin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larrywdin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2012 at 11:20pm
The NS train is one of there business cars, the locomotive in front of the car is a "Power unit" used to power the car.
Possably a business deal going on between the BNSF and NS?,,who knows any more
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 6:37am
Dave, where is all the glass and door for that 200?
1944 Allis C
1960 Allis D-17 LP
Emmo213 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Emmo213 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 7:41am
That's one of the Norfolk Southern track geometry trains. Not sure why'd it be on a BNSF line except maybe a detour. Here's a little better picture of it. (note: picture isn't mine).
http://www.railpictures.net/viewphoto.php?id=276524
Edited by Emmo213 - 20 Apr 2012 at 7:41am
'38 Allis B
'41 JD A
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 8:15am
Well it was a rough old tractor when I bought it, it hasn't gotten any better over time. LOL
The door used to pop open once in awhile, it popped open while I was mowing roads just when I was next to a sign and that was it. (It had been bent straightened and welded at least once before.) One of the side glass was a plexiglass sheet when I bought it, that didn't last long. Then I've had it on it's side twice mowing roads, I got to say the ROPS cab works or I wouldn't be here today. We don't mow ditches with it anymore, we use a batwing and a bigger tractor with the wheels set wide or duals on.
It's been a good chore / loader tractor but the power director only works in low and the hydraulics are getting weak and it has fuel system issues. I'd love to rebuild it with fenders and a factory roll bar and canopy but more than likely it's going to get traded as is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 9:22pm
Dave,
Is your F350 a diesel? I had a 67 F350 I traded for a C. Ended up the fellow who got the F350 got a much better deal. He said it just needs some seafoam...well it was much worse than that!
I miss my old F350. What kind of mileage do you get with it?
Mike
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 6:59am
I look at two things and have it pointed out to me Thayer THINGS HAVE CHANGED. One the SIZEbof the 200 nextbto the WD.
The WD was a HOSSbin my day and now it looks lost next to the 200 - which is not a HUGEbunit by today's standards.
Second a SIXTEEN ROW planter. Gee things have changed.
Guess I AM GETTING OLDER
Good Luck!
BillnLong
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 7:49am
Originally posted by allischalmerguy allischalmerguy wrote:
Dave,
Mike
It's a 460 gas, I don't think anyone has ever checked the mileage since it's been around here. It's the 5th 460 I've had in various 3/4 and 1 ton Fords so I'd estimate 8 mpg although being fuel injected it might do better.
I bought this one from a buddy and it was a "deal".
I bought it with the transmission out. Anyone need a good ZF 5 speed for a 4 wheel drive with a 351 Windsor? I was assured it would interchange but didn't know the bellhousing was part of the case. So after I had the original transmission rebuilt I have an extra. About a year later the rear end went out. Currently it's been fuel pumps. When it works it's a great truck! LOL It was a fertillizer truck so it has been used and abused. The cab floor needs some patchin up next.
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 8:05am
WHAT KIND FIELDCULTIVATOR IS BEHIND THE 8070? LOOKS LIKE A IH AND WAS WONDERING WHAT NUMBER IT IS. THANKS, RANDY
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 8:15am
Good Luck!
BillnLong
Bill, we're small potatoes today. Across the road from me is a 400 plus hp Deere 4WD with a 50' more or less field cultivator. My 8070 would look about the same next to it as the WD looks next to the 200. Later there wil be a 24 row planter show up and make short work of 160 acres and be on down the road.
My 16 row is a remnent of when I farmed 950 acres, it would keep two 7060's with 25' field cultivatos humping to stay ahead of me. Today we work 80 to 100 acres up and the next day I start planting at a leasurly pace while Andrew works up the rest of the ground. The next day I'll get done planting corn. About 220 acres of corn all together.
We used to get 160 to 200 acres or more a day depending on how much moving and what size fields we were in.
cornbinder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cornbinder Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 8:34am
nice 8070.those are workhorses!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 8:35am
Thanks Dave. Always something to fix on old trucks.
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 9:04am
It's an IH 4600 I think, just before they became CaseIH. It's a good one but I'd like a DMI or a CNH/DMI but they don't show up used in the 25 - 26 foot size around here and I'm not in the market to buy new.
Just finished planting corn yesterday. If I can get my burndown sprayed this week I might start beans next weekend. We have a chance for rain on Wednesday. Forecast is highs in the 60's to 70's with lows in the 40's next week.
I'd be surprised if we're much more than 50% planted around here, noone seems to be in much of a hurry. The ground has been working nice. After mudding in at least part of the crop the last couple years this is great. The soil is about perfect for notilling the beans. We wouldn't turn down a rain but we're not hurting for one.
Oh yes, one of the boys informed me the neighbor's Deere 4WD is 525 hp. YIKES!
Edited by Dave in il - 22 Apr 2012 at 9:12am
EClark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EClark Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 2:34pm
Dave is that a Hicksgas L.P. tank in your yard? sure look's like it. silver and green you can spot those tanks long way away.
Eric
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 3:03pm
There is a 24 row and several 16 row around me. makes my 8-30 look small. By Champaign there is a new 40 row john deere, 20 inch row, with a new tract tractor pulling it. Rumor is 1.000.000 dollar set up.
VF Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VF Farms Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 5:21pm
That 8070 looks great!
3-8550,7580,8070,8030,7010,7000,210,2-D21,2-D19,4-D17,wd's and wc's and old farm equipment
cbmoss View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbmoss Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 8:15pm
Thats some really cool stuff. I especially like the picture of the 8070. Clap
ACscott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACscott Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 8:59pm
Nice looking equipment.
