Gas tank cleaning
Steve g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve g Quote  Post ReplyReply Direct Link To This Post Topic: Gas tank cleaning
    Posted: 29 Nov 2020 at 1:55pm
Asking for input. Have a cat D2 pony motor gas tank it's about the size of standard cookie jar. It's probably a gallon, gallon a half tank. Anyhow inside the tank is pretty rusty so I'm asking input on just putting bee/bees in it and shake around wash it out with muriatic acid or doing some kind of coating process thanks to all
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2020 at 2:30pm
Weather you roll the BB's ( some use stones other nuts and bolts) around to get the loose stuff or you wash with acid you will want to put a sealer on the inside once done. The acid strips the oils out of the metal and will start to rust if not coated
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2020 at 5:38pm
If you can bolt or clamp the tank to a wheel, and do some work with the machine the wheel is attached to, it does a pretty good job of cleaning.  Also if you put a chain, of some sort, in the tank, insteada loose junk, it will be easy to remove, and be assured that there is nothing loose left in there to vex you in the future.
Scroll down in this post, to don's solution...Wink
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2020 at 7:03pm
I used milkstone remover in a tank for a 170 gas recently.  Started out using apple cider vinegar for about a week, and while this helped, it didn't get it as clean as I hoped.  I filled the tank almost full of water and then poured in half a gallon of milkstone remover and filled it to the brim with water and left it for 24 hours.  Then drained the milkstone/water and neutralized it with baking soda and water for a couple hours, moving the tank around to coat the inside.  After draining the tank again, I used a hot powerwasher with a 90 degree end on a wand to rinse out the baking soda/water.  I was real pleased on how clean the tank was.  I put in a bit of E85 to absorb the little bit of water i had left in the tank.  I used ATF and diesel mixture to coat the inside after getting the tank emptied and dried out to prevent rusting.  This tank had old dried up gas and rust in it, real nasty looking, and its looking real good now.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2020 at 8:27pm
If it's just rusty and dirty, I would skip the muriatic acid, and put in 1/4" nuts, rather than BBs.  Nuts have somewhat more squared edges, so they'll scrape it.
I'd put the tank in some sort of rotisserie that'd tumble the nuts  for a couple days, stopping it and re-orienting it's angle every four-five hours or so.... dump it out, rinse it with gasoline, then put it back in service...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2020 at 7:00am
If its only a gallon or so, why not pick up an inexpensive universal tank? With a little research, you probably could find a small Plastic fuel tank from a Garden Tractor and bolt it on. Then you don't have to mess with acids and such. A Plastic tank will last longer, and no worries about rust.  Just a thought......  HTH.
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2020 at 1:09pm
Steve has a GREAT IDEA if you dont need original... I normally  fill the tanks with rocks or nuts and a gallon or so old gas or diesel.. Slosh it around and let it scrape the tank.. I never used the acid and dont coat afterward... Just getting any flakes or major rust out.. A few small particles will be caught in your filter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve g Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2020 at 6:02pm
Thanks to all a lot of good information
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2020 at 7:20pm
We used muriatic acid on our Case loader only because the tank is not removable because it is part of the frame. It worked well especially with the pressure washer afterwords. 3 cleanings made a world of difference, the tank was full of flaking rust.
On my grandsons 3 wheeler I restored for him that use to my kids 3 wheeler, I used vinegar. It’s slower but less harmful. After 4 days, it worked well and has been clean since. Be patient if you use vinegar, but it does cut the rust, just takes some time and shaking each day.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2020 at 9:00am
Cleaned the tank on my Grandpa's WD with the tumble method. Tip; If you use a chain make sure it's not roller chain! Let's say that was interesting to get out. After the tumble it got power washed, was a lot better. I don't remember why but it got the electrolysis treatment before reinstall. This got the rust out. However the power washer didn't get all the scale. Took quite a while and several sediment bowl cleanings and in-line filter changes before it was right. Works great now.
Just got 'Grandpa' running over the long weekend, had a bad condenser.
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2020 at 9:35am
     I have used muriatic acid and Bill Hirsch's fuel tank sealer. After you flush the acid with water make sure the tank is completely dry; some alcohol will speed the drying. I have used this sealer on several tanks with good results. The first one was over 10 years ago. Good luck.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2020 at 11:04am
I normally use a length of 1/4 inch link chain tied to a wire. I slosh it back and forth. Easier to get back out than loose items like nuts or rocks.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2020 at 11:13am
As thick as the Cat pony tanks are, I cut one apart at the seem with a cut off wheel and angle grinder. Used a a wire wheel on a die grinder to clean it out. Had it all to bare metal, used mig to weld it back together.
cdsloop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdsloop Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2020 at 3:43pm
I used nuts and screws inside, and tumbled the tank strapped to a jacked up mower.  After the tumbling, I washed it out with water until it ran clear.  Then I put Evaporust in it, and rotated the tank every 24 hours until every surface had soaked.  It looked like brand new metal inside after the Evaporust treatment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2021 at 2:51pm
Be aware that those plastic tanks can be known to crack, then your worse than before. I'd clean it as many mentioned above and if you end up with pinholes I'd float some solder over the bottom. Those glue type coatings MUST BE ABSOLUTELY cured before using or the gas will melt it then that is a real PIA mess.
