Fuel shut off solenoid D-21
Bob wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob wi Quote  Post ReplyReply Direct Link To This Post Topic: Fuel shut off solenoid D-21
    Posted: 27 Apr 2020 at 9:07pm
Need a fuel shut off solenoid for a 1964 D-21 part No. V836640926 ( is available from dealer ) $325 seems a lot any other options, any help be great
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2020 at 8:00am
go to your local fuel injection pump shop, and ask for a stanadyne 26214, and the needed parts to install it. It's kinda unusual for them to fail, so you may have other issues.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2020 at 9:38am
Talking to my local AC mechanic last week, he says they tend to stick if it has been sitting for a while unused.  Use a screwdriver handle to tap the top of the injector pump so it clicks when you turn the key.  He said it can be cleaned up if you remove the top cover from the pump.
I will find out for sure on mine this afternoon.
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2020 at 9:44am
have some used  12 volt solenoids thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2020 at 8:13pm
Check your wiring !!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2020 at 9:54pm
Yep, mine didn't want to fire up after having the winter off, the stud of the solenoid was loose in the pump housing.  I snugged it up a bit and she roared to life.
This page was generated in 0.186 seconds.
