FUEL PRIMER PARTS |
SIMPLICITY
Joined: 19 Sep 2009 Location: ERATH LOUISIANA Points: 514 |
Topic: FUEL PRIMER PARTSPosted: 10 Nov 2010 at 1:14pm |
HELLO
WOULD ANYONE KNOW WHERE I CAN GET THE PRIMER PUMP SEAL ON A DIESEL PRIMER PUMP ON A 190XT,200,D-21 OTHER THAN THE DEALER, KINDA PRICEY $58.33 THIS IS THE PART ON THE END OF THE PRIMER PUMP HANDLE/ROD. THANKS THAD |
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5149 |
Posted: 10 Nov 2010 at 2:35pm |
That is a Stanadyne (Roosa Master) part. Your local fuel injection shop can get it. I have sold them here, and they are half the price of the one you mention.
SIMPLICITY
Posted: 10 Nov 2010 at 8:25pm |
INJPUMPED
WOULD YOU HAVE THE PART # FOR THE PLUNGER SEAL ? |
injpumpEd
Posted: 10 Nov 2010 at 8:46pm |
I'll post it tomorrow. It is the whole plunger assy.
injpumpEd
Posted: 11 Nov 2010 at 10:21am |
Warehouse has 11 in stock, retail is $23.02 Each, and Stanadyne part # is 23457. I could have it tomorrow to ship out to you if you cannot find one. Thanks, Ed.
Dale Hardtke
Joined: 12 Sep 2009 Location: Watertown WI Points: 171 |
Posted: 11 Nov 2010 at 10:37am |
Ed's THE MAN !!!!!!!!
injpumpEd
Posted: 11 Nov 2010 at 10:41am |
Thanks for the plug Dale! How are you, and Leon getting along with the move? LOL! later, Ed
Dale Hardtke
Posted: 11 Nov 2010 at 10:44am |
We are all done. The new building is filling up.
Hurst
Joined: 11 Sep 2009 Location: Midway, Ky Points: 1219 |
Posted: 11 Nov 2010 at 10:51am |
Is this the same primer plunger assembly that is on a late 7000? Mine leaks/doesn't prime too well too, might be something worth replacing this winter if that's what it costs.
Hurst |
1979 Allis Chalmers 7000
5800 Hours |
injpumpEd
Posted: 11 Nov 2010 at 12:12pm |
I think the plunger kit replaces all the AC, and White, and probably more. Ed.
GM Guy
Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1988 |
Posted: 07 Dec 2019 at 2:59am |
Ed, can you still get this primer pump? If so, what is current price? Agco keeps creeping up and its getting hard to justify.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
injpumpEd
Posted: 07 Dec 2019 at 11:02am |
I have parts to fix most of them. The plunger is now $46. With the 3 orings inside, and the 2 check valves, the "kit" I put together for them ends up $75 or so. Some tractors use oring fittings some use pipe fittings. Most use rubber ferrules as well connecting the fuel lines into and out of the primer, as well as most of the other lines. I also keep those parts too.
Alvin M
Posted: 07 Dec 2019 at 2:07pm |
If You Need Just Plunger Kit To Repair the Leaking The Agco Kit Part # Is 74063231 For 41.92 IH Is The Same Kit # N7519 For 37.26
