Front Wheel Weights for WD45?
bryani289swmi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bryani289swmi Quote  Post ReplyReply Direct Link To This Post Topic: Front Wheel Weights for WD45?
    Posted: 22 Aug 2017 at 7:44pm
I had a chance to pick up some weights thinking I'd put them on my WD45. That's when I noticed there are no mounting holes on my rims. Is a different rim needed or are these not meant for a WD45? I already have two of the front stack weights on it. There is a very steep hill on my road which is a county minimal maintenance road and I can never keep the front end down when grading it. Thanks.
Bryan
Sticks and stones may break my bones but hollowpoints explode on impact.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 8:01pm
The bolt goes thru the slots. Takes a special bolt. HTH Tracy
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 8:24pm
Yup, just like Tracy says.  I was pretty young and dumb when I bought mine.  $10 bucks each and all 6 holes had the "special" bolt nut and washer.  Didn't know how fortunate I was they were sold that way. So, I didn't have to find out how they worked.  When you got the special bolts they really work cool!  Sometimes I think the bolts are more rare than the weights!
JakeWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JakeWI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 8:26pm
I didn't have the special bolts so I modified some carriage bolts to go in the slots.
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 8:35pm
I used regular bolts on mine. Grind the head down flush with the bolt on one side. You will have to use a big flat washer on the weight. A bolt small enough to go thru the slot is smaller than the hole in the weight. It ain't a perfect fit but it will work.
albatros_3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote albatros_3 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 10:44pm
I used some 1/2" bolts from the hardware store. I ground down the bolt head on one side and it worked perfect. I cannot remember how long the bolts are.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2017 at 3:01am
You can still buy the square offset head bolts I think,could a few years ago anyway.
Use a square head bolt and cut off one side is about the same.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2017 at 4:35am
P/N is 223565
use a Carriage Bolt 1/2" X 3 3/4" , grind one side
Gary
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2017 at 9:40am
Boy, I've never been able to find those offset head bolts.  Where can you get them Gary?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2017 at 10:24am
A carriage bolt might hold them. The real bolt head is offset , longer on one side to catch the rim correctly. the head size pushes bolt to true center of hole. A carrige bolt won't do that, without building up the head and machining it. HTH Tracy
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2017 at 1:34pm
I've got some I made out of flat stock and all thread that work great. Would post some pics but thanks to photobucket, that won't happen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2017 at 7:39am
Used to get them from an Industrial Supply salesman,I have a bunch around here someplace if I can find them.
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2017 at 9:30pm
Matt Scott LLC had some in the classifieds a while back. He might have still have some.
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2017 at 9:40pm
Agreed that I've never seen those bolts sold.  They were an A-C special for this purpose only.  Only ones I've seen were "hand made" as most people here state.  If an industrial company makes them, it would be interesting to see them next to the "A-C special bolt".  The originals sure do work slick on those A-C rims....
