Print Page | Close Window
Front Wheel Weights for WD45?
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=141732
Printed Date: 08 Feb 2026 at 9:57pm
Topic: Front Wheel Weights for WD45?
Posted By: bryani289swmi
Subject: Front Wheel Weights for WD45?
Date Posted: 22 Aug 2017 at 7:44pm
I had a chance to pick up some weights thinking I'd put them on my WD45. That's when I noticed there are no mounting holes on my rims. Is a different rim needed or are these not meant for a WD45? I already have two of the front stack weights on it. There is a very steep hill on my road which is a county minimal maintenance road and I can never keep the front end down when grading it. Thanks.
Bryan
Sticks and stones may break my bones but hollowpoints explode on impact.
Posted By: Tracy Martin TN
Date Posted: 22 Aug 2017 at 8:01pm
The bolt goes thru the slots. Takes a special bolt. HTH Tracy
Posted By: EPALLIS
Date Posted: 22 Aug 2017 at 8:24pm
Yup, just like Tracy says.  I was pretty young and dumb when I bought mine.  $10 bucks each and all 6 holes had the "special" bolt nut and washer.  Didn't know how fortunate I was they were sold that way. So, I didn't have to find out how they worked.  When you got the special bolts they really work cool!  Sometimes I think the bolts are more rare than the weights!
Posted By: JakeWI
Date Posted: 22 Aug 2017 at 8:26pm
I didn't have the special bolts so I modified some carriage bolts to go in the slots.
Posted By: Ranse
Date Posted: 22 Aug 2017 at 8:35pm
I used regular bolts on mine. Grind the head down flush with the bolt on one side. You will have to use a big flat washer on the weight. A bolt small enough to go thru the slot is smaller than the hole in the weight. It ain't a perfect fit but it will work.
Posted By: albatros_3
Date Posted: 22 Aug 2017 at 10:44pm
I used some 1/2" bolts from the hardware store. I ground down the bolt head on one side and it worked perfect. I cannot remember how long the bolts are.
Posted By: Gary Burnett
Date Posted: 23 Aug 2017 at 3:01am
You can still buy the square offset head bolts I think,could a few years ago anyway.
Use a square head bolt and cut off one side is about the same.
Posted By: Gary
Date Posted: 23 Aug 2017 at 4:35am
P/N is 223565
use a Carriage Bolt 1/2" X 3 3/4" , grind one side
Gary
Posted By: Dave (NE)
Date Posted: 23 Aug 2017 at 9:40am
Boy, I've never been able to find those offset head bolts.  Where can you get them Gary?
Date Posted: 23 Aug 2017 at 10:24am
A carriage bolt might hold them. The real bolt head is offset , longer on one side to catch the rim correctly. the head size pushes bolt to true center of hole. A carrige bolt won't do that, without building up the head and machining it. HTH Tracy
Posted By: IBWD MIke
Date Posted: 23 Aug 2017 at 1:34pm
I've got some I made out of flat stock and all thread that work great. Would post some pics but thanks to photobucket, that won't happen.
Date Posted: 24 Aug 2017 at 7:39am
Used to get them from an Industrial Supply salesman,I have a bunch around here someplace if I can find them.
Posted By: Auntwayne
Date Posted: 24 Aug 2017 at 9:30pm
Matt Scott LLC had some in the classifieds a while back. He might have still have some.
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
Posted By: EPALLIS
Date Posted: 24 Aug 2017 at 9:40pm
Agreed that I've never seen those bolts sold.  They were an A-C special for this purpose only.  Only ones I've seen were "hand made" as most people here state.  If an industrial company makes them, it would be interesting to see them next to the "A-C special bolt".  The originals sure do work slick on those A-C rims....
