Tractomotive Loader TL |
MNLonnie
Orange Level Joined: 11 Sep 2009 Location: Baxter MN Points: 4790 |
Posted: 30 Jun 2013 at 9:57am |
What kind of fluid do you guys run in your transmissions (Tractomotive clutch type) on the TL-6, TL-10, TL-11 or TL-12?
Waukesha B, B, IB, G, styled WF, D15, 615 backhoe, 2-Oliver OC3's, 6 Ford Model T's, 3 Model A Fords, AV8 Coupe, AV8 Roadster, 1933 Ford Wrecker
iceberg210
Bronze Level Joined: 20 Jun 2012 Location: Boise Points: 29 |
Automatic transmission fluid, note that this fluid also runs the power steering. I believe the level was standard 4 or something that they are now on standard 6 or something so any ATF will do... Also make sure to clean out the strainer on the return line, my TL 12 had that plugged which was a lot of where my issues were... If you have any other questions let me know, the old Tractomotive/AC machines are absolutely incredible especially for their time and are awfully handy to have around.
MNLonnie
I have a parts book for the machine but I would like to get an owners/operators manual for it if one is available.
iceberg210
JenSales Manual sales I know had one for the TL 12,
Don't know if they have one for the TL6 http://www.jensales.com/Search.html#/Search.html?search=allis+chalmers+tl6&category=F50996 |
MNLonnie
I've looked there and they only have a manual for the motor since it's a B-125. Do you have anything that will explain to me how to adjust the clutch to get the right amount of pull?
MurphyLake
Silver Level Joined: 17 Mar 2013 Location: Wisconsin Points: 171 |
My TL10 has the serial #35 and the torque converter is 36.
I worked it on a farm for several years without leaks. An auxiliary hydraulic outlet was added to the front to operate a tree spade. The engine was upgraded to a WD45 iA Charlyn pump was added for power steering. Some time after restoration the torque converter began to leak. It became so constant so as to make the machine unusable . The engine has been removed four times to get to the converter seal. The shaft has a single ring for a seal. The leak continues.. Looking for a solution.. Edited by MurphyLake - 16 Jul 2013 at 10:52pm |
MattLF9
Bronze Level Joined: 27 Nov 2009 Location: Minnesota Points: 187 |
Solution: haul to scrap yard.
A little CQB never hurt anybody.
JohnCO
There has got to be a problem with the torque converter, worn out or whatever. How much work would it be to put a different one in? Things like that just wear out over time. Scrap Yard are almost four letter words - never to be spoken in regards to Allis Chalmers!
Allis Express participant |
MattLF9
I'm wondering if you have a groove worn into the converter and it won't allow it to seal?
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29521 |
Groove in the shaft, a little extra wear on a support bushing, all little things internally worn to allow a little extra movement and clearances.
