Carburetor for WC Puller |
Post Reply | Page <1234> |
Author | ||
mlpankey
Orange Level Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
Yeah why you think it a siameese port issue when its a timming issue. Ever checked each cylinder on a stock crank for tining difference. If you have a electronic ignition with reluctor tabs its a simple fix but a points distributor is nearly imposiible to fix without some funky grinding on points.how to large a carb lean up a siameezed issue like you tend to state over and over again in numurous posts. Why is Siameze a issue on three and four and not one and two. Timing. When you richin a carb up its done cause of a plug reading showing to lean. Which plug is it is it all of them is it one timming is set by or is it another cylinder.if it was a siameeze port feeding issue the it would show up on a compression test on a fresh build as variance in cylinder pressure cause a cylinder with more air to compress will show a higher pressure when compressed.
Edited by mlpankey - 18 Feb 2013 at 9:11am |
Sponsored Links | ||
mlpankey
Its good to still be needed all the kids from wis with unbelievable little engines that can need instruction.
mlpankey
Wi pulled his page two post. Why did you.
mlpankey
Edited by mlpankey - 18 Feb 2013 at 10:38am |
wi50
Because I don't have countless hours to alienate you this week.....we know you're an idiot and we don't need to prove the same thing every 2 weeks.
But I do think with those timeing issues you think you have, you need to find someone to index crankshafts properly when grinding.
mlpankey
I think you dont know the difference in timing variance between cylinders and a rich lean fuel condition. Just inexperience covering up one for another.
unstylish_
Silver Level Joined: 19 Dec 2012 Location: southwestern Mi Points: 129 |
Mitch, if you'd ever been to Wisconsin you'd see that there is no reason to go anywhere else. As far as tractors not pulling anywhere else, where have you been pulling lately? Oh yeah..... Or were you pulling in fantasy land again? Oh sorry, your reality. Where the " ruler is named compression" and some other crap. Y did you ever change that wonderful saying you used to have?
mlpankey
Unstylish you made a.comment on yt about a computer timing controlled allis with.individual coil packs. Would you care to tell the forum the thoughts that ma e a dude go through the efforts to do so.
Experience enduring problems and solving in time that others havent had the time to endure yet let alone work out. The reason engines come to us to fix what others cant. Edited by mlpankey - 18 Feb 2013 at 12:00pm |
unstylish_
Is that going to your slogan when you take something to someone elses machine shop and call it your own? I wanted tohave a tractor with out a distributor. You know why ? It'd be cool. I never did it on an ac. Instead I dud one on an mm hd800 for a guy who ran 4500 rpms with a pair of 4 barrels on it. It was just an expirament . Because we could .As far as computerized timing goes, that project is probably going to happen in a few months. You should be able to figure out the advantages of that, yourself. I'd hope. Did you get your motor that you were so busy assembling done? did you get your "brothers" from Michigan done? You must have to secretive about them, so no on talks them out of pissing their money away on the likes of your ability. Im afraid this is probably all the time I'll have to respond to you this week. Beating you down has become so old lately and my the guy i work for is having open heart wed morning. I still have a lot of moline machine work to complete, including getting ready to finally complete ethans motor .
mlpankey
I know the advantages of timing each cylinder individually. Its obvious your buddies dont. They must think that 10 degrees advance on 1 is 10 on all but thats just not always the case. Inless the reluctor tabs on the electronic pickup have been bent to compensate and that takes having top dead center marked for every cylinxer as well. Most are to lazy to do thate.
Carl(NWWI)
Orange Level Joined: 13 Sep 2009 Location: NW WI Points: 948 |
Can you speak english? I swear a 5 year old can write better sentences, ones that actually make sense too. Its funny though spank, all the "little" engines that could from Wisconsin can, and win. And continue to win. Nothing of any good seems to roll outta TN |
mlpankey
Dont see them out of wis.winning.
WildBill
Silver Level Joined: 26 Aug 2012 Location: Mandan,ND Points: 190 |
If you read statistics the badger is the hardest to compete. I'm not from Wisconsin but I do know Panky will have his ass handed to him if he ever showed. Pankyyouwilllose. Mayb he can read that? Idk
Allis fan for life ! B,C,2-WC'S,WD45G,D19G,190xt ,LLSS 8010, terra tiger refurbished
mlpankey
Seams like everyone comes south to pull in the winter but dont recall a wis.tractor winning.
Even though most of us tn boys get dqued so yanks can win.seams like the carpet baggers still want to impose their rules. |
Carl(NWWI)
Well it tends to get like -800* up here with 30ft of snow, so its a lil hard to pull tractors. Nothing from WI wins huh? Mine wins, wi50 wins, another one he did work on wins, I've pulled against it, Allis200puller wins with his. Ratitude won in gordyville.... |
mlpankey
Somebody read the little engj.e that could way to much on them snowed in days.
O.P.S. Heads
Orange Level Access Joined: 02 Jan 2013 Location: Iowa Points: 574 |
If you can't have too big of a carb, then why didn't all 350 Chevy's come with an 1150 dominator? Hell, why on earth did they ever make so many different sizes of carburetors for so many application over the years? Stupid engineers. They have no idea what they are doing obvioulsy.
Carl(NWWI)
Lol! Who needs carbs, just throw a garden hose in the manifold and let the gas flow!
Here's a pic that fits are town clown pretty good. Too much inbreedin going on. |
mlpankey
Edited by mlpankey - 19 Feb 2013 at 10:09am |
Ihateillinoisnazis
Orange Level Joined: 15 Jan 2013 Location: By The Lake Points: 273 |
What??? None of your ramblings make any sense. Babbling and spewing doesn't make you sound smarter spunky. Haven't you figured this out yet? Post something factual with sources that aren't Wikipedia for a change, really quit spamming the forum with . Stinks like a manure pit around here with all your bull. |
mlpankey
what opens the butterfy on a carb for a antique pulling tractor? The govenor. If the carb is large the gov is only going to open carb up enough for engine to run its governed rpm meaning the carb isnt going to flow its full cfm flow . If the gov opens a small carb full open to get high idle then you have no reserve left to maintain high idle. . If that doesnt make sense you probably shouldnt own a engine and still be riding a bicycle.
Ihateillinoisnazis
Then why is a four barrel a four barrel?? Why not just one big toilet bowl and let the butterfly / slide whatever is used as a metering device control the size of the carb??? Does intake velocity mean anything to you? How about the speed air is moving through a Venturi... Take a lesson on air flow sometime. If you look around Wi gives lots of good advise. Maybe you can get a free lesson.
unstylish_
Mitch, thats the dumbest statement youve made yet...if you knew ANYTHING about tractors governors or carbs at all...well, we all know that answer...You OBVIOUSLY dont know chit about govs and carbs. Whick goes back to your story about turning 6000 rpms when your gov broke,..all cock n bull lies.
mlpankey
unstylish i knew you where still riding a bicycle. 3456 rule
you obviously never set a gov throttle linkage either . cause if you have you know with the engine off throttle pulled wide open you want the carb wide open.
Edited by mlpankey - 19 Feb 2013 at 1:52pm |
Butch(OH)
Orange Level Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3831 |
If you had ever flowed one instead of reading BS on the internet and then posting it here you would know that Q jets came in two sizes only. The smaller one would flow between 730 and 750 and the best of the larger ones would make 800. I have less time with the AFB but dont remember one over 800. This would be with castings that had to make stock rules at an NHRA meet and at the standard vacuum for 4 barrel carbs or 1 1/2" Ya Spankster, even dumb ole Butch has spent some hours on a flow bench. Now, when the magic carb BSers want to fool idiots into thinking they own some magic wand for carbs they simply flow them at a higher vacuum such as the 3" vacuum that is standard for flowing 2 barrel carbs or pic whatever reading you want, the higher you run the vacuum the more CFMs yo can crow about. Then add some polish, put it in a bright colored box with Hi-flow written on it and idiots like you line up to buy them. |
Rod B
Orange Level Joined: 25 Jul 2011 Location: Peoria Points: 415 |
Hey spankey, on page 1 you say you ran a usx21 carb. Then go on to say to run a big carb and trim the fuel. Why do you then say that you can never have a carb to big?
Contradicting isn't it. A usx21 isn't that big of a carb. It's capeable of less than half the airflow of what wi50 was uses on his Allis. Now I understand that when you can't get much air through a cylinder head, it's pointless to put a big carb on. |
SuperM74
Bronze Level Joined: 27 Jan 2013 Location: Hustonville,Ky Points: 22 |
I think i will go with pankey, i will make a inverted manifold and put a 1050 Dominator on it........ LOL!!! I think that should feed the 226 just fine, then have a custom cam ground.... How about 270 duration @ .050, 106 centerline, and 640 lift. That should really do the trick for a 2000 rpm engine....
You can't make chicken salad, outta chicken sh*t! Proof's in the pudding!
mlpankey
mlpankey
Rod B
