wd45 starter problems
MarkinSIndiana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarkinSIndiana Quote  Post ReplyReply Direct Link To This Post Topic: wd45 starter problems
    Posted: 04 Sep 2012 at 7:14am
My 45 broke the nose on the starter about 6 months ago. yesterday it broke again. is something going on that I am not catching?
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2012 at 7:24am
is there maybe a shim that is missing. the only thing I can think is that the starter is not alligned correctly and is binding, causing it to break. is the starter maybe staying engaged?
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2012 at 7:58am
Check your engine timing because if it is off it can cause this problem. I know cause it happened to me last year. Starter repair took one and told me to recheck timing.
