serial numbers wd 45
theACkidWD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote theACkidWD45 Quote  Post ReplyReply Direct Link To This Post Topic: serial numbers wd 45
    Posted: 28 Mar 2012 at 6:39pm
i recently purchased a supposed 1957 wd 45. i researched the serial no. locations. the one on the left brake housing is not there i took the paint down to bare metal and still no luck.  any help in locating the serial no would be greatly appreciated  i want to verify the yr
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 6:47pm
Look at the engine number and cross reference to Bryan Smiths chart. The other possibility is on the top flange of the hydraulic pump. I have several with serial numbers there, but they don't always match the tractor number.
Edited by John (C-IL) - 28 Mar 2012 at 6:49pm
RickUP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickUP Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 6:50pm
It's NOT ON TOP of the left brake housing. If you stand behind the tractor, it will be facing you. (I have a feeling you knew this). Scraping the paint should have revealed it. Had to do this to mine. Look some more I guess.
Post Options Post Options   Thanks (0) Thanks(0)   Quote theACkidWD45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 6:51pm
im not around the tractor now but i did find a serial number infront of the shifter
Post Options Post Options   Thanks (0) Thanks(0)   Quote theACkidWD45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 6:52pm
i had the entire tractor down to bare metal and i couldnt find any numbers on the left brake housing  kinda stumped
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickUP Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 6:54pm
That number in front of the shifter is cast into the housing. Sorry I never looked into what it's for,but the serial number will be stamped.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 6:57pm
Early WD's were stamped on TOP to the right side of the left brake cover. All 45's should have a stamp on the back of the differential housing unless it has been replaced.
If it is a curved shifter and there is no stamp were indicated, take a look at the hydraulic pump housing and compare engine numbers here:http://people.clemson.edu/~wsmth/SNFind/esn_tsn6.htm
Post Options Post Options   Thanks (0) Thanks(0)   Quote theACkidWD45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 7:01pm
it does have the curved shifter and no inspection plate on motor. just no stamped or casted no. in the indicated location
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickUP Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 7:01pm
Some wimp on the hammer stamped mine. It's very hard to see with my old wimpey eyes. Ya gotta look close. It's real fact.
Post Options Post Options   Thanks (0) Thanks(0)   Quote theACkidWD45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 7:04pm
the man i bought the tractor from gave me the original owners manual and still no luck but ill look on the pump housing. thanks for the insight.
This page was generated in 0.032 seconds.
