HD10 TRANS and Final drive oil |
Argo2
Bronze Level Joined: 28 May 2010 Points: 37 |
Posted: 25 Mar 2012 at 8:22am |
Has anyone had any experience with upgrading the recommended oil for the transmission and final drives on the HD1O. The book says 30 weight Motor oil for both in winter, 50 weight in in summer. The reason given in the book was that other oils might destroy the neoprene seals.
It seems that there should be a better high pressure alternative. Any suggestions? |
gemdozer
THE TRANSMISSION AND FINAL DRIVE SHOULD HAVE 80/90 OIL
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41195 |
finals I would use a GL5 rated gear oil , 80/90 seems about right.
On trany I would also look at something with extreme pressure rating as it also is the ring and pinion lube . Would say GL5 - 80 or another EP oil
Headerpuncher
Bronze Level Joined: 18 Jan 2012 Location: Ea. Wa. Points: 5 |
I would be carefil about using any EP oil in the transmission. Probably OK for finals but anything with brass bushings etc will not tolerate EP oils. The brass will turn to a black crumbly stuff and get funny trails in it like worm holes or groves. 50 wt motor oil is the perfered choice. Don't ask how I know. Just don't do it. Sulphur which is a component of EP oils will react with the brass and all it does is cost money.
Argo2
It appears you are quite correct in saying not to use 85/90 gear oil. After your comment I got hold of the research and development dept of Shell oil and they confirmed that 30 or 50 weight motor oil is right and then said that if I wanted a better shear capacity and slightly more lubricity to use a trans hydraulic oil 30 or 50 weight depending on season. To say the least I was surprised.
Headerpuncher
Thanks for the research and reply. Most of my education came from reading my checkbook.
Edited by Headerpuncher - 27 Mar 2012 at 3:20pm |
catskinner
Silver Level Joined: 18 Mar 2012 Location: Walla Walla WA Points: 61 |
We have used 80/90 in finals 50W in trans. for more than 40 years
Whatever it is, I'm against it! (Groucho Marx)
