wd 45 diesel throttle linkage
bdowning View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bdowning Quote  Post ReplyReply Direct Link To This Post Topic: wd 45 diesel throttle linkage
    Posted: 24 Jan 2012 at 5:11pm
I am putting back together a wd diesel and can not find the throttle linkage that goes between the pivot on the side of the block and the injection pump. I believe it is 1/4 inch rod about 4.5 inches long and bent on both ends, but I was wondering if someone could give me a good length on that so I can make one.
Thanks
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2012 at 7:38pm
mine measures 4 3/4 center to center on the factory mfg rod.i used 1/4 in rod with ball ends on my other diesels.works real good especially with all the vibration from that buda.get them at napa....
Post Options Post Options   Thanks (0) Thanks(0)   Quote bdowning Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2012 at 9:06pm
Thanks
