THE NEW COVER-BOARD?
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Topic: THE NEW COVER-BOARD?
    Posted: 24 Dec 2011 at 8:46pm
I have a 70s series plow with cover boards that say "THE NEW COVER-BOARD" on the back of them were these made by AC or after mkt.i have seen alot of AC plows with them. TOM
Edited by ctbowles58 - 25 Dec 2011 at 5:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2011 at 6:00pm
BUMP
Rick Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Miller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2011 at 8:33pm
I have the same coverboards on a 4 bottom I am restoring I think they are aftermarket but not 100% sure . I'm thinking about trying to get the decals reproduced.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2011 at 9:15am
These were on my Dad's #73 semi-mounted SC plow.  I believe these were aftermarket additions versus original AC equipment, but I could be wrong.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2011 at 9:47am
So what bottoms are those? Plow bottoms aren't defined by the plow model. Each plow model or plow frame takes about a dozen  different bottoms and each bottom takes different moldboards, frogs, shin, and mostly shares. Landsides are shared between many bottoms. A few shares were used on a couple bottoms.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2011 at 10:18am
Gerald, I couldn't tell you what bottoms those are; it sat outside for too many years.  Couldn't read any numbers.
When I "re-did" the plow, I used different shanks & bottoms from a different "donor plow" where the bottoms, shins, moldboards and landsides were all in better shape than what I had as shown in this picture.  I didn't use these coverboards either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2011 at 1:17pm
I have 3-14 & 4-14 SC W/375 bottoms and the cover boards in Brian's photo. Work good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2011 at 1:23pm
i have a set of these off of a 70s series with 375 moldboards i wonder if thay will fit a 2000 series with 387 moldboards ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2011 at 2:36pm
They mount on the moldboards, not the plow frame but my plow bottom book that is early 387 vintage shows no holes in the moldboards for extensions. But these mount up top, not at the rear so may need new holes in the moldboards. In the bottoms on my plows (one Case and one 2000 Monoframe with 392 bottoms) these cover boards would only add weight to the plow, with the coulter set 1/2 or 3/4" left of the landside the top inch of the moldboard doesn't even scour because at that point the moldboard is taller than the width of the slab being turned. They might do something if there wasn't sharp coulters out front otherwise nothing would touch them.
Gerald J.
