DIY repairs |
Steve allis dozer
Silver Level Access Joined: 10 Apr 2011 Location: Australia Points: 232 |
Posted: 10 Apr 2011 at 5:49am |
Running older machines Sometime you have to make your own parts
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21536 |
Man that sure is pretty ! Too bad it'll get dirty soon !!!
You'll have to take one of the belts off thouh and move it a 'tad' to line up with the other one, lol !
Tad Wicks
Orange Level Joined: 27 Mar 2011 Location: Shandon, CA Points: 2160 |
Well done, , it turned out beautiful,you have a bit of time in that project. Nice clean shop, nice tooling, Great Job. Tad
JPG AUSTRALIA
Orange Level Joined: 13 Sep 2009 Points: 733 |
great job steve,I'm impressed, keep them going.
omahagreg
Orange Level Access Joined: 11 Sep 2009 Location: Omaha, Nebraska Points: 2799 |
WOW! That there is PURDY!
Greg Kroeker
1950 WD with wide front and Freeman trip loader |
Kipn
Orange Level Joined: 12 Sep 2009 Location: Tewksbury, Ma Points: 800 |
Nice job. Just curious on what your yellow paint code that you used was?
1961 H3
Steve allis dozer
Hi all, thanks for the replies , Paint colour is old cat yellow. steve
rayfromTX
Bronze Level Joined: 08 Jan 2011 Location: TX hillcountry Points: 5 |
Man that is awesome. Congratulations on a fine job.
Rawleigh
Orange Level Joined: 14 Sep 2009 Location: White Stone, VA Points: 421 |
What lathe tool did you use for turning the v belt groove? I had to be pretty small to get all the way to the bottom. BTW, beautiful work!!
Edited by Rawleigh - 12 Apr 2011 at 3:25pm |
Steve allis dozer
I machined the front side recess then turned it around held it there with the inside jaws got it running true with a dial indicator , machined the whole lot including the bore and keyway without taking it out so it all ran true,( the original pully was balanced but i figure this was because it was cast and some surfaces were not machined) for the grooves I used a 3mm wide parting tool down to the right depth, then a home made tool which i had to hold at the back of the toolpost as the pulley was to big for my lathe , for the surface the seal runs on i fitted a stainless speedy sleeve and polished with emery cloth.
The keyway was done using a home made tool held in the toolpost then winding the saddle back and forth with the lathe switched off and in low gear as not to move . steve
Rawleigh
Nice tool setup to machine the grooves! Necessity is the mother of invention, isn't it! Do you have a picture of the tool you used to make the keyway? Thanks and nice work.
