confuse with coil polarity WD45
sunsation288 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sunsation288 Quote  Post ReplyReply Direct Link To This Post Topic: confuse with coil polarity WD45
    Posted: 30 Jan 2023 at 10:38am
hello all , i have remove my coil on my WD45 for painting purpose , and i didn't  take care of polarity on my coil ? , i know i have 12 volt negative ground system  , but i have found on the internet this picture ...i am ok if my igniton switch to the  positive side of the coil ?
sorry for be time consuming !!!
my very best regards
christian
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2023 at 11:08am
christian
Yes like the red on the pic. Switch to + side of the coil and - to the distributor on a negative ground system.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2023 at 11:11am
Neg Gnd feed points, ign sw feeds + side coil
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2023 at 12:09pm
'Red' is right, for you...
'Blue' is bad, well it actually will work, but not as good a spark......
You will not damage anything if you miswire the coil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2023 at 12:27pm
if you connect it up backwards ( the BLUE photo).. you will have current flowing BACKWARD thru the point and condenser in addition to the coil... not an ideal situation.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2023 at 8:35pm
Distributer is the ground just like battery. If battery is pos. ground, coil is pos. grounded to distributer.               MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2023 at 6:52pm
Christian,
Don't forget, you have a Pertronix electronic ignition I fixed you up in that new Distributor  so, from the E.I. in the Distributor, the RED wire goes to the plus (+) side of the coil, and the BLACK wire from the E.I. goes to the Negative (-) side of the Coil. The circuit from the Ignition switch goes to the plus (+) side of the coil with the RED wire from the E.I.  I don't want to see you burn out your new E.I. The fellers here don't know you have an E.I.
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote sunsation288 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2023 at 4:51pm
thanks all for your help !!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote sunsation288 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2023 at 4:56pm
Christian,
Don't forget, you have a Pertronix electronic ignition I fixed you up in that new Distributor  so, from the E.I.......  I don't want to see you burn out your new E.I. The fellers here don't know you have an E.I.
Steve@B&B
yes i know Steve thanks to taking care of me  , i just receive my new carburator , and i wish to start my tractor and adjust the carb and after all the fuel side adjustement work well , i will change my distributor E.I.
hope my reply made sense ?
