confuse with coil polarity WD45
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=193181
Printed Date: 28 Apr 2024 at 6:54pm Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: confuse with coil polarity WD45
Posted By: sunsation288
Subject: confuse with coil polarity WD45
Date Posted: 30 Jan 2023 at 10:38am
hello all , i have remove my coil on my WD45 for painting purpose , and i didn't take care of polarity on my coil ? , i know i have 12 volt negative ground system , but i have found on the internet this picture ...i am ok if my igniton switch to the positive side of the coil ? sorry for be time consuming !!! my very best regards
Posted By: Thad in AR.
Date Posted: 30 Jan 2023 at 11:08am
sunsation288 wrote:
hello all , i have remove my coil on my WD45 for painting purpose , and i didn't take care of polarity on my coil ? , i know i have 12 volt negative ground system , but i have found on the internet this picture ...i am ok if my igniton switch to the positive side of the coil ?sorry for be time consuming !!! my very best regards | Yes like the red on the pic. Switch to + side of the coil and - to the distributor on a negative ground system.
Posted By: captaindana
Date Posted: 30 Jan 2023 at 11:11am
Neg Gnd feed points, ign sw feeds + side coil
------------- Blue Skies and Tail Winds Dana
Posted By: jaybmiller
Date Posted: 30 Jan 2023 at 12:09pm
'Red' is right, for you...
'Blue' is bad, well it actually will work, but not as good a spark......
You will not damage anything if you miswire the coil.
------------- 3 D-14s,A-C forklift, B-112 Kubota BX23S lil' TOOT( The Other Orange Tractor)
Posted By: steve(ill)
Date Posted: 30 Jan 2023 at 12:27pm
if you connect it up backwards ( the BLUE photo).. you will have current flowing BACKWARD thru the point and condenser in addition to the coil... not an ideal situation.
------------- Like them all, but love the "B"s.
Posted By: MACK
Date Posted: 30 Jan 2023 at 8:35pm
Distributer is the ground just like battery. If battery is pos. ground, coil is pos. grounded to distributer. MACK
Posted By: Steve in NJ
Date Posted: 31 Jan 2023 at 6:52pm
Christian, Don't forget, you have a Pertronix electronic ignition I fixed you up in that new Distributor so, from the E.I. in the Distributor, the RED wire goes to the plus (+) side of the coil, and the BLACK wire from the E.I. goes to the Negative (-) side of the Coil. The circuit from the Ignition switch goes to the plus (+) side of the coil with the RED wire from the E.I. I don't want to see you burn out your new E.I. The fellers here don't know you have an E.I.
Steve@B&B
------------- 39'RC, 43'WC, 48'B, 49'G, 50'WF, 65 Big 10, 67'B-110, 75'716H, 2-620's, & a Motorhead wife
Date Posted: 01 Feb 2023 at 4:51pm
thanks all for your help !!!!
Date Posted: 01 Feb 2023 at 4:56pm
Steve in NJ wrote:
Christian, Don't forget, you have a Pertronix electronic ignition I fixed you up in that new Distributor so, from the E.I....... I don't want to see you burn out your new E.I. The fellers here don't know you have an E.I.
Steve@B&B
yes i know Steve thanks to taking care of me , i just receive my new carburator , and i wish to start my tractor and adjust the carb and after all the fuel side adjustement work well , i will change my distributor E.I. hope my reply made sense ?
