8050 Power Shift Problem
gl nelson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gl nelson Quote  Post ReplyReply Direct Link To This Post Topic: 8050 Power Shift Problem
    Posted: 29 Sep 2022 at 7:33pm
I have an 8050 power shift that sometimes will not shift into 5th.  Sometimes it hesitates and then shifts, other times it will not shift into 5th, and sometimes it shifts fine.  Once you get it to shift into 5th, it seems to work fine from then on the rest of the day.  Just recently I put it in reverse and let the clutch out, and it didn't want to move.  About half an hour later I tried reverse again and it worked fine.  The linkage adjustment feels fine.  I am wondering if it could be something in the valve assembly.  Just wondering if anyone has any idea of what might cause this.
Thanks,
Gary
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2022 at 8:28pm
Sounds like a linkage problem inside valve body. A linkage brakes some times, but shifter don't feel right.                       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote gl nelson Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2022 at 9:18pm
The shifter feels like it always has.  If you take the valve body off, you can get to that linkage?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2022 at 10:02pm
Yes. Don't need to drain oil.                  MACK
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2022 at 6:24am
Taking the valve body off is not nearly as bad of a gig as it would seem. I prolonged doing it on my 7060 because I was dreading it. After doing it, it was like, "why didn't we do this a long time ago!"
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2022 at 7:31am
Anyone have pictures of it with valve body off
Post Options Post Options   Thanks (0) Thanks(0)   Quote gl nelson Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2022 at 6:40pm
Thank you all for the help.  After I get done planting wheat I will take it off and see what I find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2022 at 7:55pm
You're parking it, right ?? Using a Power Shift when you know there is a problem isn't usually a wise decision.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gl nelson Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2022 at 7:57pm
Yeah it is parked
